What do you have to do to get the cr85 clamps to the klx110 head tube? I've searched but found no answer.
This is a discussion on Cr85 Triple Clamps within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; What do you have to do to get the cr85 clamps to the klx110 head tube? I've searched but found no answer....
i just got done with my build with the showas. what i did was pressed out both steering stems and put the 110 stem into the lower 85 clamp and it bolted right up. the stem had to have a brass shim put around it to make it tight so i had it tig welded from the bottom side to make sure it wasn't ever going to come out.
