Best Big Bike Style Rearend ? Klx110.
This is a discussion on Best Big Bike Style Rearend ? Klx110. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Gday everyone .
Building a full mod 110 and want the very best rear end setup , from shock to swingarm .
elka/fox/ishock etc
and ...
Gday everyone .
elka/fox/ishock etc
and the numerous swingarms that are or where available..
chp/sano/bbr/bigminis etc etc
its gonna be on a custom frame , that is essentially the Billetware klx frame with a extra inch in length. (thanks drz63
Is limited to big bike style setup .
Im coming from a k-Lxr with the bigger frame , which was alot bigger then regular full mod klx's . so i would probably go for the longest swingarm you could get ?
Do they all work pretty much the same , depending on which shock you run ? or does the different shock angles etc make alot of difference etc.
Thanks everyone!
12-06-2011 09:30 PM
I have a BBR supercomp and my friend has a pitster pro rear end. The BBR feels more nimble in the tight turns because its only 2.5 inches longer than stock. It feels amazing when the track is tacky. But I noticed its easier to slide-out and loose control when you got lots of horsepower, and the terrain starts getting dusty or muddy. And in fast, rough stuff, its not as stable feeling. I'm sure when the BBR swingarm is matched to their perimeter frame, the stability is improved. ...or maybe my set-up is just set too stiff? I'm still playing around with the shock. My friend has the DNM shock with a 900 lb spring so it feels more plush and forgiving than mine.
I also like the fact that I can still use my stock drum brakes. The Elka shock feels great, but it would be awesome if there was high and low speed compression adjustments.
Thanks for the input , by pitster pro rearend , do you mean the x4r swingarm ?
I always thought the bbr supercomps where longer then 2.5 , unless they make different sizes ?
Thanks!
Also im running 188cc SE head , reversed manifold , taky special clutch , cr trans etc etc . so its a fast and snappy engine!
Went tru some old(07) pitbike mag(minimoto) and they seemed to like the Sano MX kit best, said the swingarm was built like a bombshelter and it was the longest,Arms and shocks tested,CHP,BigMinis,Sik110s,Sano.
Any other imput , dave ?
Thanks pitviking , do you no what type it was .. i think there was 2 different versions of the sano mx styles ?
It's the one in the top picture.
that top one looks like the sano ls8 which is a nice setup with a fox podium, me and my brother have ran supercomps with elkas,chp's with podiums, and ive had a bbr superpro with elka, and im currently running a bigminis with an elka, id say we liked the chp swinger with the podium the most the shocks are amazing and the swinger just looks sick, next i love my bigminis setup, we havent had good luck with the supercomps seems like were always replacing the bushings in the shock and the whole idea of the shock block i dont like, the chp and bigminis are really simple and really easy to work on! CHP>BIGMINIS>SUPERCOMP, IMO
Bigminis is what I have and I love it to death. I've ridden with a few supercomps before and they don't come close to how good the Bigminis feels.
Originally Posted by
wogtaz ryder
Thanks!
Yup, he has the X4r rear end. I'm pretty sure the supercomps are 2.5 inches. They even look physically shorter than all the other MX swingarms out there. Seems like a lot of other riders agree that the BBR isn't all that great...but the other good thing about it is that you can still get it brand new and there's still parts for them. I don't see too many of the other swingarms for sale.
I have to say, that CHP swingarm looks awesome. I like how the cutouts are on the outside of the swingarm where its easier to clean and less likely to pack with mud from your rear tire.
solidjohnny
Should this be limited to brands that you can buy NEW ?
Thanks heeps for the replies everyone ! got me thinking.
So is it fair to say the fox is the best shock to use?
wogtaz ryder
Personally i like the fox podium the best but there hard to come by and expensive to buy new, but if ya got the money thats the shock i would spend it on!
There has been tons of these topics asking about swingers and shocks go to the top and search a few things .... I know a couple topics was named " A style or mx style" another was which is better "A style or mx style" make sure your searching the right thing like forum or topic if you type that stuff in and search member you might not get anything but I know I started one a while back and a couple other Katz did too and there was a ton of information ppl posted on mine and the other peeps that did seriously take and hour or so and search it
Yer cheers mate , i have just always had trouble searching this site . will have a look when i get home .
ya everyone has there own opinions and im sure mostly everyone on here has rode 8 different setups like i have lol
Elka - BBR Supercomp = Not bad in my opinion little ridgid and doesnt soak up everything
Elka - BBR Superpro = very similiar to the supercomp but i felt was a little softer than the supercomp setup
Fox Podium - CHP = Very close to the best setup , fox shock is hands down the best shock ive ran and fully adjustable , short swingarm
Elka - Bigminis = Also one of the best ive ran , soaks up mostly everything and very nice when coming up short on jumps , long swinger
Racetech - TwoBros = another pretty long swingarm and felt soft for everyone one ive rode , cant go wrong with this price setup
2006 Dagner Built Bigminis
2013 Piranha Anima190
Thanks to Wholesale-Cycle, TB Parts and BBR Motorsports
- You may not post replies
- You may not edit your posts
Forum Rules
bbr swingarm klx110
big bike swing arm klx 110
big bike swingarm klx110
klx 110 big minis rear end
klx 110 mx style swingarm
klx 110 swingarm
klx 110 swingarm mod
klx110 big bike swingarm
klx110 swingarm pitster
mx style swingarm for klx 110
mx style swingarm for klx110
mx swingarm pivot dimension
