2002 Klx110 Big Bore Kit
This is a discussion on 2002 Klx110 Big Bore Kit within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; i have a 2002 klx110 and i want to put a big bore kit in it but i cant find one that will work with ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i have a 2002 klx110 and i want to put a big bore kit in it but i cant find one that will work with a 02 does any one no were i can look and can u bore your stock cylinder to a 143 so i can just buy a piston and head and a carb.
    to live is to die, but die on a bike
    is doin' your mom
    gncc_jake's Avatar
    Jul 2008
    Marietta, Ohio
    If you wanna do that you might as well pull the head off, push the piston down to the bottom of its stroke and drop a grenade inside. The bottom end of the 02 wont handle much abuse....weak
    Rankin141's Avatar
    Jun 2010
    Chula Vista, CA
    ^What he said. Don't bother with the 02
    Hillz's Avatar
    Feb 2007
    West Oz
    arnt they the same motor from 02/09?
    Rankin141's Avatar
    Jun 2010
    Chula Vista, CA
    02's had bad cranks and bad transmissions. Very prone to breaking. The different styles are 02, 03-04, 05-09, '10+.
    is GET OFF THE COUCH AND GO RIDE
    MG577's Avatar
    Mar 2009
    North K.C. Missouri
    Can you put a new crank in an 02 like out of my 06
    Podium Performance, Team ECC
  7. #7
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    i think it will be fine can u bore the stock cylinder to a 143 though
  8. #8
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    also the bike is like brand new it only has probly 15hours on it it has hardly ever been used i think it will be fine i am going to get a big bore then port and polish the head and get a cam and exuahst and carb and stuff
  9. #9
    is Took Portland's job. I may be
    getting demoted again...
    Jarret53's Avatar
    Aug 2009
    Massachusetts
    you can't bore the cylinder that big, i bored mine to a 130 and don't know if you can go larger with ought sleeving it. Tbolt has the best prices and options for 143 kits. You can also check the classifieds and get a used cylinder and do new piston and rings and be ready to go. Ive been told you need to do a crank and head to really get all the use out of the 143. I would be scared to use a 2002 motor. Look for a used motor on here they might have everything you want plus more!
  10. #10
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    Quote Originally Posted by Jarret53 View Post
    how does the 130 do
  11. #11
    MG577's Avatar
    Mar 2009
    North K.C. Missouri
    Any bore kit you buy for around $200 new with everything is going to be worth the money,for the power gain.
  12. #12
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    Quote Originally Posted by MG577 View Post
    how much power will i gain if i run every thing stock but put a 143 big bore kit in
  13. #13
    Jarret53's Avatar
    Aug 2009
    Massachusetts
    my question isn't how much power but how long the bottom end will last. If you try it out let us know!
  14. #14
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    ya i have to get the money im only 15 and this summer i am going to get a job and do some stuff to mine im just going to do a super stock 110
  15. #15
    bfaith's Avatar
    Dec 2011
    grandjunction co.
    Quote Originally Posted by klx110s for life View Post
    what is a pritty easy cheap way to get more power out of a 110
2002 klx 110 big bore
2002 klx 110 big bore kit
2002 klx 110 for sale
2002 klx110
2002 klx110 review
best big bore kit klx110
best klx 110 big bore kit
klx 110 143 big bore kit
klx 110 143 bore kit
klx 110 143 power difference
klx110 big bore review
