BBR klx110 top end rattle.
This is a discussion on BBR klx110 top end rattle. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just got a new BBR full mod klx110, there is a rattle, not a quite one. I'm almost positive it's coming from the top ...
I just got a new BBR full mod klx110, there is a rattle, not a quite one. I'm almost positive it's coming from the top end, should i be worried? if so what should i do?
Thanks..
P.S bore kit is the 143cc by TB with racing head.
02-26-2012 06:21 PM
Race heads make noise, it's the valves is all, completely normal. I was worried too at first when my engine made a rattle/tick sound but got over it. Make sure your valves are at the correct last and your cam chain isn't sloppy. Is it coming from the head?
Originally Posted by
Jordo
AN ENTIRE 110CC CYLINDER CAN FIT INSIDE MY BORE!!!! I HAVE A BIG BORE WITH CRAZY INSAIN HEAD WORK!!!!!!
not sure exactly where its coming from.. its load though, I believe it starts (or gets loader) when i rev it..
Valves get louder as the RPMs increase. Do you have access to a camera to snag a video? It's incredibly hard to diagnose from here.
Jordo
I do, but at the moment my clutch is taken apart, would be together but i broke the right engine cover gasket. once its all together i will start it up and video it.
Sounds like its about to blow up! Sell your bike to me for super cheap
But seriously, valve noise is different than a rattle. If I were you, and I had any doubts, I would tear that engine completely down, grab my mic or calipers, and measure every little piece.
ok if i am going to tear the top end down, do i need the "special tools" in the service manual?
dont tear it down unless your going to rebuild it.. if its a ticking sound thats loud and you have a v2 head you have nothing to worry about thats just the sound they make..
okay, how do i know if its v2 or not?
koby686
okay found out i got the v2, so its normal? its like easy to hear and my bike is really loud..
check to make sure the cam sprocket bolts are tight
which one are those? i'm kinda a noob
cover on the left side of the head take the 4 bolts out and there it is. the cam sprocket and chain
keith150
oh yeah, okay i will check those, Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
By stlavsa in forum Chinese/Import Minis - General Discussion
Last Post: 06-15-2010, 06:50 PM
Last Post: 01-28-2010, 11:04 AM
By MickUK in forum Chinese/Import Minis - General Discussion
Last Post: 08-26-2009, 02:07 AM
By xr50rider14 in forum CRF50
Last Post: 06-04-2009, 09:53 PM
By kidd1029 in forum Roost Area
Last Post: 02-15-2009, 09:57 PM
bbr super head klx110
drz 110 engine rattle noise
drz 110 making noise after fresh rebuild
klx 110 engine rattling
klx 110 top end rebuild
klx110 ticking noise in motor
klx110 valve noise
klx110l new top end
lifan 125 ticking rattle
rattle in lifan 110 engine
valve rattle
why does my klx 125 make a ticking noise
