klx 110 ticking noise
This is a discussion on klx 110 ticking noise within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; hey so i put in a bbr 130 bore kit in my stock 110. i am now hearing a ticking noise. it ran perfectly fine ...
Results 1 to 3 of 3
    dehn257's Avatar
    Mar 2012
    hey so i put in a bbr 130 bore kit in my stock 110. i am now hearing a ticking noise. it ran perfectly fine before i put the bore kit in. I put two other ones together an they run mint, no ticking . It is timed right, the valve clearence is right, the pistons arent hitting the head, i dont know what it is, i think my crank is going out. can anybody help me? thanks
    is ready to ride.
    TheStock50Kid's Avatar
    Jul 2011
    Massachusetts
    If your crank was on the way out.. Get a piece of wood. lightly punch the wood very quickly. That's what it would sound like. Knock knock knock.. Chances are it's your valve lash, double check it, you may have done it 100 times before but 1/4 turn of the adjuster and you're off a mm or 2. Could just be valve train noise.
    Hidden Content Originally Posted by Jordo Hidden Content
    AN ENTIRE 110CC CYLINDER CAN FIT INSIDE MY BORE!!!! I HAVE A BIG BORE WITH CRAZY INSAIN HEAD WORK!!!!!!
    Hidden Content
    dehn257's Avatar
    Mar 2012
    it ticks from start up. it also done rev up like it should.
  1. Ticking Noise
    By joeymay in forum Chinese/Import Minis - General Discussion
    Last Post: 12-06-2011, 01:36 PM
  2. loud ticking noise from motor
    By kman153 in forum KLX110, DRZ110, TTR90
    Last Post: 07-11-2009, 09:11 AM
  3. ticking noise
    By jtblueberry in forum KLX110, DRZ110, TTR90
    Last Post: 08-20-2008, 06:01 PM
  4. Replies: 1
    Last Post: 03-21-2005, 09:47 AM
  5. Ticking noise from clutch cover?
    By blackjer in forum CRF50
    Last Post: 03-14-2005, 08:50 PM
big bore kit ticking sound
klx 110 making clanking sound
klx 110 ticking
klx 110 valve noise
klx 110 vavles ticking
klx110 ticking
klx110 ticking noise in motor
klx110 valve noise
klx110 valve tick after bore kit
klx110 valve ticking
slight ticking noise in drz 110
Tags for this Thread
