Aftermarket fork springs
This is a discussion on Aftermarket fork springs within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just received a set of aftermarket fork springs for a klx110. The springs are two different lengths. One is 17" and the other is ...
I just received a set of aftermarket fork springs for a klx110. The springs are two different lengths. One is 17" and the other is 17 1/2". I have not removed the stock ones yet, so what I was wondering is: is this on purpose to create a progressive feel or should they be exactly the same. If they should be the same, do you think one is shorter than intended or longer? I was going to use one in my klx and one in my kx60 fork. I understand the kx60 spring is longer, so I would use the longer one in the kx (probably still with a spacer) and the 17" in the klx forks. What do you think?
04-05-2012 06:43 AM
Does anyone know the length of a stock klx110 fork spring and a kx60 fork spring?
I got some stock kx60 springs at home ill measure them tonight and let ya know.
My stock kx60 springs and the minibikespring HD springs I have in my kx60 forks are 19 inches long.
Darn I was hoping they were closer in length. Thanks for measuring. I got these springs from tbolt, they say they are longer and stiffer. I wonder what a stock klx measures. I guess I am going to have to pull them both apart this weekend.
- You may not post replies
- You may not edit your posts
Forum Rules
By RompKING282 in forum CRF50
Last Post: 10-22-2008, 08:53 PM
By dehno in forum KLX110, DRZ110, TTR90
Last Post: 09-28-2007, 09:13 AM
By Conway in forum CRF50/CRF70 Parts For Sale
Last Post: 08-24-2006, 02:00 AM
By AtvMxRyder in forum CRF50/CRF70 Parts For Sale
Last Post: 08-22-2005, 03:44 PM
By Outlaw50 in forum CRF50
Last Post: 11-19-2003, 08:41 AM
fork spring length different
klx110 fork one stiff 1 stock
kx 60 fork springs amazon
kx60 fork springs
purpose of aftermarket fork springs xr50
ttr 90 fork springs
ttr 90 springs
ttr90 fork mods
ttr90 springs
what is the length of 110 fork springs
xr 50 fork springs
