Can someone give me an idea of what weight oil and how much for my KX65 forks?
This is a discussion on Can someone give me an idea of what weight oil and how much for my KX65 forks? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I'm a 150lbs dude, and I just got some 65 forks. I was told when I bought them that they were already set up. But ...
I'm a 150lbs dude, and I just got some 65 forks. I was told when I bought them that they were already set up. But They bottom on a smallest whoop. I just need a starting point. Thanks!
04-11-2012 09:53 AM
- You may not post replies
- You may not edit your posts
Forum Rules
By catfish in forum KLX110, DRZ110, TTR90
Last Post: 03-29-2011, 11:11 PM
By crazysammi87 in forum KLX110, DRZ110, TTR90
Last Post: 04-24-2010, 06:04 PM
By spyr_409 in forum KLX110, DRZ110, TTR90
Last Post: 01-22-2010, 10:35 AM
Last Post: 07-09-2007, 01:26 AM
By T-BOMB in forum KLX110, DRZ110, TTR90
Last Post: 09-21-2006, 06:40 PM
drz oil viscosity
drz110 flywheel weight
how much fork oil do i run in klx110 forks
how much fork oil do you put in kx 65 forks
how much fork oil should i put into a kx65 fork?
klx110 fork oil weight
klx110 oil viscosity
kx65 fork oil
kx65 forks klx110 oil weight
ttr 90 oil type
what fork oil should i use in a 07 kx65
what fork oil weight to use kx 65
