found out it is not a two brothers swingarm it is a Metaltek Long Travel Swing Arm. does anyone have any idea what bearings go in this? want to ride and this is holding me up?
Thanks
This is a discussion on Older two brothers swingarm within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; found out it is not a two brothers swingarm it is a Metaltek Long Travel Swing Arm. does anyone have any idea what bearings go ...
Thanks
See this thread:
Need Help Two Bros Swinger
2Bros Gen I uses KX65 swingarm bearings & seals.
This is confirmed to fit. I put the PivotWorks kit into my Gen I swinger.
Perfect fit. Seals work fine also..
Thanx again to born2ride14 for this crucial information...
I just found out from a friend that it is not a two bros swingarm that it is a Metaltek Long Travel Swing Arm. any idea where i can find these bearings?
does anyone have any ideas?
I've heard that they are pretty much the same swingarm, and that for a while Metaltek was building swing arms for Two Bros. Maybe call Two Bros and talk to Joel Albrecht.
ill give that a try thank you.
finally got a hold of metaltek they also use kx65 swingarm bearings and also kx65 chain guide incase anyone needs to know in the future.
