I left the on/off switch on like an idiot and it drained the battery. I got a sik110's ott brake lever so I removed the kick starter too. I'm racing Sunday should I just charge it and it'll be good to go or should I buy a new one to be safe?
This is a discussion on 2012 klx110 battery died? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I left the on/off switch on like an idiot and it drained the battery. I got a sik110's ott brake lever so I removed the ...
put the kicker on for alittle bit and let it run it should charge it.
See I did that and rode it around for like 30 min and it charged a lil but was still real weak when it turned over off the electric start
you will be fine...I did this with my L once as well. Just keep riding it. It will charge itself unless the battery is bad, which it isnt since its a 2012.
Right on will do. Thanks man
