KLX110 suspension questions
This is a discussion on KLX110 suspension questions within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Im wanting to make my 110 sit a little higher, seeing as im 6'2". But i was thinking of doing a kx 65 font end, ...
Results 1 to 7 of 7
    kawi143's Avatar
    Feb 2012
    Indian Trail, NC
    Im wanting to make my 110 sit a little higher, seeing as im 6'2". But i was thinking of doing a kx 65 font end, but i do that would it be a direct bolt on if i used kx 65 triples? and if i did could i still use the sucky drum brakes that are on it now? and would going from a 10" rear shock to an 11" make a big difference?
    ja564rm80's Avatar
    Jan 2008
    Mt. Morris
    the kx 65 forks are not a direct bolt on. The stem diameters are different from the stock 110 triple tree to the kx 65 triple tree. I believe they now make a set of bearings that u can buy to make it work with the kx 65 stem. If you dont want to do that u can grind the weld on the bottom of the klx triple tree and press the stem out. then grind the stem on the kx 65 and press that out. Press the klx stem into the kx 65 trees and weld it in there and bam. It is now a bolt on to stock klx bearings. and im am pretty sure that u would need a +4 swinger or a mx style swinger to get the bike to sit remotely level. Other wise it will be raked out. I have a complete pitster front an rear susp with EVERYTHING that is needed to bolt it on. I can make u a hell of a deal on it if your interested. pm me if u r
    is bored at school, wanna ride
    Joey55robinson's Avatar
    Apr 2012
    san diego
    im 6 3" and im running the kx 60 forks and a stock swingarm with an i shock with the klx/drz 110 bars and i have plenty of room and it sits level just from adjusting the forks up more in the tripple camps... less money and i prefer the stock swingarm look compared to the +4 one
    Apr 2012
    san diego
    pro taper klx/drz bars **
    is the faster i go the faster i
    crash
    RockSStR_999's Avatar
    Jan 2012
    Alpine, Ca
    i have the same exact set up as joey55 except with a racetech rear shock and the ride height feels perfect to me, it raised my bike 2-3 inches,,,,and a 11in. shock will raise you up, thats what most aftermarket shocks are
    kawi143's Avatar
    Feb 2012
    Indian Trail, NC
    Alright cool, doesnt two bros make a triple clamp kit to mount 65 forks to a 110? and I was just looking at the bbr E6 fork kit, anybody run those? any good?
  7. #7
    is ready to put some laps in on
    the minis
    elixur's Avatar
    Dec 2007
    Seattle/ Eatonville, Washington State
    Bbr e6s are good quality forks just like everything bbr.
    Not sure about two bros making clamps I know brp makes some and so does brandx.
    If your set on 65 forks I have some with brp clamps I am getting rid of. They are stock internals actually have two sets of forks. Ill make you a deal on both and you can put the other on ebay and get the money for a wheel and brake setup. Pm me if your interested they are also listed in the 110 classified section.
  1. Suspension Questions
    By cjohnson_8118 in forum Chinese/Import Minis - General Discussion
    Last Post: 11-16-2011, 12:14 AM
  2. Suspension questions?
    By Dasupertech in forum KLX110, DRZ110, TTR90
    Last Post: 08-25-2010, 01:04 AM
  3. suspension questions?
    By brtsuzuki480 in forum CRF50
    Last Post: 05-11-2008, 11:13 PM
  4. KLX110 Suspension Questions/Advice...
    By MXDadFL in forum KLX110, DRZ110, TTR90
    Last Post: 04-28-2005, 06:44 PM
  5. 110 Suspension Questions.
    By DirtySouthRacing in forum KLX110, DRZ110, TTR90
    Last Post: 03-29-2005, 10:39 PM
best klx 110 shock
drz 110 suspension
how do i udjust my klx110 suspension
klr 110 suspension upgrade
klx 110 shock upgrade
klx 110 suspension
klx 110 suspension mods
klx 110 suspension upgrade
klx 110 suspension upgrades
klx 110 with kx65 suspension
klx110 suspension
klx110 suspension upgrades
