TB155 vs tb143 reliability
This is a discussion on TB155 vs tb143 reliability within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; This may be a dumb question, but reliability-speaking, is there any difference between going from a 143 to the 155 with the addition of the ...
Results 1 to 13 of 13
    is Round 7 of MO State series was
    fun!
    traut811's Avatar
    Nov 2008
    Ste. Genevieve, MO
    This may be a dumb question, but reliability-speaking, is there any difference between going from a 143 to the 155 with the addition of the 55mm crank? Also would a 155 be too much in a stock mod, and would it still be ride-able in trails, or should I go with a 143? I don't want a full-blown race engine I have to rebuild every 15 hours, I want something bulletproof like a 88 stock head kit I ran the piss out of for 4 years in my xr50 lol.
    Only big bore klx I've ever ridden was a 177 or something
    is GET OFF THE COUCH AND GO RIDE
    MG577's Avatar
    Mar 2009
    North county S.D.
    The 143 with the stroker crank is going to be a lot for the auto clutch to hold ,you would have to run all stiff springs and it would be hard to shift .
    The 143 is very reliable even with the stroker crank ,
    From the sounds of it the 143 kit would be perfect
    fun!
    traut811's Avatar
    Nov 2008
    Ste. Genevieve, MO
    Quote Originally Posted by MG577 View Post
    Thanks for the reply! My engine has the chp manual clutch, but thats it as far as I know.. Is the 143 a significant power increase, or would I be better off saving up for Stroker crank to install that the same time as the shift drum and output shaft?
    Anyone have any rough estimate guesses on hp numbers with a 143 or 155 engines, both with v2 heads and appropriate carbs?
    is If you're not first, you're
    last
    crf50kid309's Avatar
    Feb 2010
    moorpark CA
    Make sure you do the 4th drum and output shaft and while you are in there mine as well do the stroker crank!
    is Baller on a Budget!
    locojo25's Avatar
    Apr 2009
    Mount Morris, N.Y.
    Either way you should buy my 143 kit in the for sale section! I am an advocate for the stroker though!
    fun!
    traut811's Avatar
    Nov 2008
    Ste. Genevieve, MO
    Quote Originally Posted by locojo25 View Post
    Haha work with me a bit more than you have it posted for, and I will
  7. #7
    beastlywarrior228's Avatar
    Jan 2011
    Mogadore, Ohio
    id want it but im not up for breaking into the bottom end to replace the stupid output shaft. maybe if it was a lower compression
    02 warrior xc built
    05 klx110 stocker project
  8. #8
    is a slow rider on a fast bike
    solidjohnny's Avatar
    Nov 2007
    Honolulu, Hawaii
    mine is holding up great so far. Plenty hours on it. I think it'll be fine for a stock mod. Once you get a racehead and the motor is craving for high rpm, then it'll be a bit much to handle unless you are riding on glass....
  9. #9
    locojo25's Avatar
    Apr 2009
    Mount Morris, N.Y.
    Always open to offers!
  10. #10
    fun!
    traut811's Avatar
    Nov 2008
    Ste. Genevieve, MO
    Ive been texting you lol, 573 535 9955
  11. #11
    is braaaap
    mx_freak's Avatar
    Mar 2010
    houston
    A 155 is a bit much to me for a stock mod especially for trail riding I have a 155 full mod and I'm clearing most jumps at our local big bike track to me it takes the fun out of STOCK MOD 143 is plenty for trail riding in my experience the 155 hasn't been as much fun as the the 143 was because I'm blowing all my friends away and I could go on but just trying to give advice to a fellow rider good luck!
  12. #12
    fun!
    traut811's Avatar
    Nov 2008
    Ste. Genevieve, MO
    Quote Originally Posted by mx_freak View Post
    Words I soaked up from beginning to end, very useful input
  13. #13
    locojo25's Avatar
    Apr 2009
    Mount Morris, N.Y.
    I personally love having the ability to blow my friends away! you dont always have to twist it wide open. Plus I like the down low of the stroker for climbing steep hills on the trails!
  1. Daytona 150 Reliability
    By Rankin141 in forum CRF50
    Last Post: 05-03-2011, 01:14 PM
  2. Reliability ?
    By audi 0000 in forum Chinese/Import Minis - General Discussion
    Last Post: 03-15-2011, 08:15 AM
  3. Reliability of he 150r
    By Wandell in forum Honda CRF150R And CRF150F
    Last Post: 05-06-2010, 10:31 PM
  4. tb 143 vs tb 165 reliability??
    By twosmoke30 in forum KLX110, DRZ110, TTR90
    Last Post: 06-25-2009, 10:55 PM
  5. Reliability
    By tbarber531 in forum CRF50
    Last Post: 07-19-2007, 09:52 PM
143 bore with stroker crank
does stroker crank to 155 make a difference
klx 110 155 stroker
klx 155 big bore jetting
klx 165 tb kit with a stroker crank relibably
klx tb 155
klx110 143 stroker
klx110 155z crankshaft
klx110l rebuild
tb 143 reliability
tb143 stroker
tb155 pitbike
