4speed drum install question
This is a discussion on 4speed drum install question within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just got the cases back together after installing a TB 4 speed drum. I know I didn't get the forks switched around. It'll shift ...
Results 1 to 4 of 4
    nick novice's Avatar
    Jan 2006
    STL
    I just got the cases back together after installing a TB 4 speed drum. I know I didn't get the forks switched around. It'll shift from neutral to first. But that seems to be it. Any ideas? I'm about to pull the right case cover off and examine the shift linkage to see if I possibly (and hopefully) don't have it installed correctly. Any suggestions would be deluxe. I don't want to split the cases again until I've exhausted all else. I really think it's installed correctly. I installed it in neutral as directed by the manual.
    jordon372's Avatar
    Sep 2008
    Valley Center, CA
    Its probably the shift linkage. If you shift it when the cover is off it pops out of place.
    mr.skywalker's Avatar
    Mar 2008
    louisiana
    I had to work on one that did the same kind of thing. After tearing it down found out the previous owner had put the forks into the wrong slots on the shift drum. I hope its some thing simpler but that was my experience.
    Make sure your shift star didnt loose a pin because that would do the same thing and that is a quick fix.
    Jan 2006
    STL
    I'll look into it tonight. But I'm wondering if I could have put the forks in the wrong slots. Without looking at it, I can't say. But I'm hoping that I didn't set the linkage up right. I know the pin in the shift star is in properly. That's one of teh few things I can rule out at this point. I've split many cases, and these were a pain to split as well as reinstall. It was weird.
  1. AHP 4speed install?
    By StlSrt4 in forum CRF50
    Last Post: 04-08-2009, 04:11 PM
  2. 4speed drum
    By Earl109 in forum KLX110, DRZ110, TTR90
    Last Post: 07-08-2008, 06:10 PM
  3. 4speed Drum Time Install Estimate?
    By realgraverobber in forum KLX110, DRZ110, TTR90
    Last Post: 05-01-2008, 03:56 PM
  4. 4speed Drum Time Install Estimate?
    Last Post: 04-30-2008, 11:55 AM
  5. drz110 4speed shift drum
    By hotsauce34 in forum CRF50
    Last Post: 02-20-2006, 01:55 AM
4 speed in ttr90
4 speed shift drum klx110
change 05 klx110 into a 4 speed
crf50 shift linkage diagram
how to align the shift linkage on a crf50
installing 4 speed drum in klx 110
installing a 4 spd in a crf50
installing shift drum in klx 110
intalling a 4 speed shift drum klx110
klx 110 4speed drum installation
tb 4 speed
turn ttr90 into a 4 speed
