Upgrade Brakes ?
This is a discussion on Upgrade Brakes ? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Is there something i can do to make my STOCK front and rear brakes work better for cheap ? Thanks...
Results 1 to 5 of 5
    YMX's Avatar
    Jan 2012
    Upgrade Brakes ?
    is reviving PM one post at a
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    get some new pads and try a different front lever with more leverage. Other than that they're drum brakes for an 8 yr olds bike.
    YMX's Avatar
    Jan 2012
    Witch lever and pads ?
    is a slow rider on a fast bike
    solidjohnny's Avatar
    Nov 2007
    Honolulu, Hawaii
    asv levers give you more leverage. You could even try an MSR raptor ez-pull clutch perch.
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    ^^^pretty much what he said. EBC makes some slotted pads and you can also scuff up the inside of your hub slightly with some sandpaper so its clean in there and nut full of brake dust.
  1. KLX110 Upgrade to rear disc/hydraulic brakes help
    By LFC911 in forum KLX110, DRZ110, TTR90
    Last Post: 02-11-2010, 03:29 PM
  2. formula brakes, grimeca brakes, zoke wheel
    By mutinytattoo in forum Feelers and What is my bike/parts worth?
    Last Post: 11-07-2009, 09:40 PM
  3. Upgrade Brakes ---> OGM SX150 pro
    By minirdr in forum Roost Area
    Last Post: 07-14-2008, 11:46 PM
  4. WANTED: ASV Lever for Forumula or Hayes brakes (Marzocchi brakes)
    By five21racing in forum Bikes and Parts Wanted - All Makes
    Last Post: 04-02-2008, 09:50 AM
  5. Complete KX60 wheel, tire, brakes, 38T sprocket and brakes
    By 5nine8 in forum CRF50/CRF70 Parts For Sale
    Last Post: 06-12-2007, 08:06 AM
klx110 drum disc brakes versus drum
more leverage on front drum brakes
slipping brakes on the ttr 90
what can i do to make my crf50 rear drum brake work better
