Klx 110 jumps when put into first gear and its hard to shift
This is a discussion on Klx 110 jumps when put into first gear and its hard to shift within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Okay so I had gotten this Klx 110 and I'm starting to put money into this but my problem that I am trying to figure ...
Results 1 to 11 of 11
    Klx110stroker's Avatar
    Jul 2012
    Dallas Texas
    Okay so I had gotten this Klx 110 and I'm starting to put money into this but my problem that I am trying to figure out is that every time I start it up and put it into first gear it almost pops a wheelie and lurches and it's a huge pull. Now for a little kid this would about throw him off.and the gears are very hard to shift threw. I have to put in gear for other people because they can't do it. Any help or ideas of what could be wrong I would appreciate it.
    is reviving PM one post at a
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    try adjusting the clutch. Its the bolt on the clutch cover. If that doesnt fix it the dogs may be worn causing the hard shifting.
    Jul 2012
    Dallas Texas
    How could I fix it
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    adjust the clutch, or replace the dogs which would require the cases to be split. Maybe someone else has another idea but I don't know anything other than those two that would cause that.
    Banned
    is living life one jump at a time
    xr-50-Tang's Avatar
    Jul 2012
    SoutWest MN
    Maybe try going through clutch, I've heard sometimes the disk might rub together and hard to shift into second, does it shift in other gears good?
    Jul 2012
    Dallas Texas
    It's still pretty rough throughout all the gears. They sell a quick shift or something like that. Do u think that would help it. And what would be the cause of the jumping of the bike when I put it in gear?
  7. #7
    Petersen112's Avatar
    Jan 2010
    McHenry, IL
    Simple test: lift up on the shifter, hold it there into first and hit the throttle. If the bike moves, the clutch is not adjusted properly and you then need to use a screwdriver and and 12mm wrench to adjust the nut on the side of the clutch cover. Loosen the nut and mess with the screwdriver going both directions until you get to the point where holding up on the shifter and giving it gas does not make the bike move. This would be the cause of the hard shifting and jumping when going into gear
  8. #8
    koby686's Avatar
    Apr 2008
    California
    Turn down the idle.. If its jumping into a wheelie with no throttle that would mean your idle is high and that is also why it's hard to shift because it always wants to go
  9. #9
    Jul 2012
    Dallas Texas
    If I turn down the idle then it won't stay running. Right now I have the main adjuster on the carb at 1/4 of a screw out from all the way in. If I turn it down then it won't stay at idle. It will just die if I don't give it gas. I live in dallas Texas so the elevation isn't high or anything but it just won't stay at idle if I turn it down. I'll just try petersens idea
  10. #10
    Banned
    xr-50-Tang's Avatar
    Jul 2012
    SoutWest MN
    i wouldnt worry soo much bout ur idle and carb suggestions but
    its gotta be something with the clutch.
    Check:
    CLutch basket, maybe the disk are dissengaging right
    Check your oil, thick oil might not help
  11. #11
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    oil isnt going to make the bike jump....adjust the clutch and let us know what happens then.
  1. Hard to shift..
    By Kawikid356 in forum Honda CRF70
    Last Post: 07-06-2012, 05:50 PM
  2. Bike Jumps Out Of Gear?
    By helmsracing in forum KLX110, DRZ110, TTR90
    Last Post: 10-26-2011, 10:49 AM
  3. 4th gear hard shift
    By kingdomstyle in forum KLX110, DRZ110, TTR90
    Last Post: 12-25-2009, 02:00 PM
  4. 2nd gear jumps off, why?
    By dax in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-25-2009, 05:28 PM
  5. too hard to shift
    By rlm996 in forum Chinese/Import Minis - General Discussion
    Last Post: 09-18-2008, 05:40 PM
ct70 jumps in first gear
how to make gear shifting easier on klx110
how to make klx110 shift easier
how to shift on a klx110
kawasaki klx110 jumps forward when put in gear
klx 110 difficult to shift
klx 110 hard shift
klx 110 hard to shift
klx 110 only has first gear
klx 110 shifts hard
klx110 hard to shift
klx110 hard to start
