I really like motul 5100 also,little expensive but works great..
This is a discussion on enigine oil within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I really like motul 5100 also,little expensive but works great.....
MiniCartel,Kennedy Racing,661,Universal,ODI grips
how much oil should i use in my klx 110 L with a 134 big bore kit
Lucas 10w-40 motorcycle racing oil, for break in. Depending on climate and load, Run 20w-50 after its been broken in for hard racing or extended run times. I run my motors for a while, So I switch to a synthetic blend lucas 10w-40 after about 20hours, No Oil burning or clutch issues!! Any reputable M/c oil is good, Honda GN4 10W-40 is also an excellent choice. I ve seen on Honda Goldwing websites, reccomending Shell Rotella 15w-40 as a motorcycle oil. Rotella is listed as a universal oil and will not make your clutch slip according to many resources.. Food for thought, since ya can get it all day at walmart. I run delo 15w-40 in my toyota 22r with 330,000mi with no blowby or oil losage.... Anyway any good 10w-40 motorcycle is probably fine I am just a bit more religious than most.
Klx110s use like 1.1 quarts or something just put a quart it then a little pour from another start it for a bit then just use the sight glass to finish it up. Easy
