compression loss
This is a discussion on compression loss within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Long story short I was pulling into the pits from racing(low idle) and the bike died. I had 5 races with each one with around ...
Results 1 to 6 of 6
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    compression loss
    Long story short I was pulling into the pits from racing(low idle) and the bike died. I had 5 races with each one with around 8 mins of run time, motor ran good with no signs of issues, I tried kicking it over but the kick starter moves freely like there's no compression. 06 motor with 08+ output shaft and manual clutch, drained the oil and it was still pretty and clean(changed before race day), checked the valves and they were good, pulled the plug and it looked good.
    I was thinking maybe clutch plates were worn??Tthey were replaced alittle over a yr ago but the bike is raced on pavement
    Thoughts?
    is reviving PM one post at a
    time.
    jdmp's Avatar
    Jun 2005
    pinellas FL
    wierd....I would definately start at the clutch
    Klx110stroker's Avatar
    Jul 2012
    Dallas Texas
    Hey man same thing happened to me today. It's the clutch. Pull the clutch lever in fast a bunch. The slave cylinder is sticking inside from lack of pressure build up... So just put it all back together. Untill u start to get compression. Then once u get compression stick it in first gear and do a take off a few times till it gets back to normal. That should help
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    Another thing to add is that I checked to see if I put it in gear and roll it if it has compression and it does
    I was thinking maybe the cultch was sticking but idk now, lol... I will try pumping the clutch when I get home, only thing is its a cable clutch not hydralic
    is getting better with Age!
    Smokeum28's Avatar
    Mar 2006
    Houston Tx,
    valves maybe to tight! check lash!
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    Quote Originally Posted by Smokeum28 View Post
    that was one of the frist things I did
    both at .003, .004... same as I always set them at
  1. Taki 88 Loss Of Compression
    By Harfi in forum CRF50
    Last Post: 05-19-2011, 01:57 PM
  2. loss of power.
    By bigmike311 in forum KLX110, DRZ110, TTR90
    Last Post: 06-12-2009, 11:37 PM
  3. Loss of power
    By wheelE in forum Chinese/Import Minis - General Discussion
    Last Post: 09-19-2008, 05:33 AM
  4. old 70 head to Lifan BVH, loss of compression
    By dax in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 12-17-2007, 07:55 AM
  5. Replies: 16
    Last Post: 01-09-2006, 02:45 PM
klx 110 compression loss
put a clutch in my 110 now it has noi compression
slow loss of power klx110
xr50 kickstarter no compression
