Help Me plan my Build
This is a discussion on Help Me plan my Build within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; what's up guys Im a mini noob and need some help planning my klx110 build. I'm going to buy a roller to start with. I ...
Results 1 to 12 of 12
    Benzy's Avatar
    Jul 2012
    what's up guys Im a mini noob and need some help planning my klx110 build. I'm going to buy a roller to start with. I basically want the best bike for the money . I want to be able to ride a track with it and be competitive on it . I need help on what forks swingarm shock and basically everything I need on it. It's my first build so I don't want to spend 5k on it. All I know is I plan on using the piranha 140 in it. Help me out guys!
    is BBR stuff is sick
    Markopolo400's Avatar
    Dec 2006
    Rochester, NY
    The 140 wont work, the engine mounts are different. Instead get a 143 kit and V2 head.
    Benzy's Avatar
    Jul 2012
    ok thanks. for suspension will a sx65 or kx 65 front end fit without modification?
    is Big bikes have put a damper on
    the little ones.
    Jarret53's Avatar
    Aug 2009
    Charlton Massachusetts (Near Thunderbowl)
    You have to press the 110 stem into the 65 clamps. Not big job. My friend had a local machine shop help him out
    is So many things I want, but so
    little money haha
    tjmazz13's Avatar
    Sep 2010
    Baltimore, MD
    Quote Originally Posted by Markopolo400 View Post
    +1 I ran a 143, V2 race head, and a mikuni 26mm carb. Fun little bike.
    Benzy's Avatar
    Jul 2012
    What do you suggest for the forks, swingarm, and shock?
  7. #7
    the little ones.
    Jarret53's Avatar
    Aug 2009
    if you want good results for less money i would pick up some kx60 forks with stiffer springs (fit in 110 clamps) a +2 swinger and a fox float
  8. #8
    Benzy's Avatar
    Jul 2012
    If I go with 65 forks Ill go with the SX65 front end. I love the look of the ktm front fender and from what I read, their basically Marzocchi forks.
  9. #9
    Dec 2006
    Rochester, NY
    Quote Originally Posted by Benzy View Post
    They are.
  10. #10
    Benzy's Avatar
    Jul 2012
    Okay cool. When I get back from Hawaii Im gonna go pick up a 110. I found a stock one for 1000. Probably get it for 700 though.
  11. #11
    234wheeler's Avatar
    May 2009
    So Cal
    Do yourself a favor and forget about the KLX110. I just built one up for my nephew and what a pain to find good parts. Used suspension alone was about a grand. You have to replace almost everything on them to make them a decent adult bike. I have a Piranha with a YX160, V2 head, VM26 carb, that's it. It's got everything, disc brakes, tall seat, cradle frame, manual clutch, 4-speed, quality suspension, and it's based on the CRF70 which is a roomier layout. The KLX has none of that stuff. If I were buying now, I would buy the new Piranha with the Daytona Anima engine. Not even $3000. My 2 cents
  12. #12
    dr-z's Avatar
    Oct 2011
    York, PA
    Buy a stock bike. Get a peg bar seat some xr50 bend pro tapers a longer brake cable. Damning rods springs a float 35t rear sprocket 143 stock head with a 26mm carb a d2 pipe and bam. I folding shifter and over the top brake pedal. Hell I even buy stock tires for mine. That set up is perfect IMO and bullet proof
  1. Lets plan something!
    By Mx353 in forum General Event Talk
    Last Post: 06-26-2012, 08:39 PM
  2. I have a plan
    By Ands1 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 03-18-2009, 07:32 AM
  3. Here's my plan
    By arlindsay1992 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-11-2008, 01:03 PM
  4. What is a better plan?
    By TP83 in forum CRF50
    Last Post: 02-07-2006, 09:29 PM
  5. Build Plan for a Rookie 50īs Ramp
    By bAsTi in forum CRF50
    Last Post: 10-06-2005, 08:07 AM
