Dodgy 3rd gear
Dodgy 3rd gear
This is a discussion on Dodgy 3rd gear within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Hi all got a 03 110 with a143 kit and having trouble getting it into 3rd under load ,it's fine going slow and on a ...
Results 1 to 11 of 11
Thread: Dodgy 3rd gear
    bigs#8 klx143's Avatar
    Feb 2013
    Dodgy 3rd gear
    Hi all
    got a 03 110 with a143 kit and having trouble getting it into 3rd under load ,it's fine going slow and on a stand but giving it the beans it don't wanna go in been shifting in mid flight of a jump just to get in 3rd
    any ideas guys ????
    Many thanks bigs
    cpitre8's Avatar
    Oct 2009
    Possibly a shift fork?
    KTMripper511's Avatar
    Mar 2013
    Change gearing mabey
    is "Ride it like you stole
    it"......
    Skooter's Avatar
    Dec 2012
    Planet Earth - Houston. Texas
    It's either a bent shifting fork or worn out dawgs. Not to expensive if you can do it yourself.
    Skooter
    dbramper223's Avatar
    May 2011
    Vermont
    I have a motor that's doing the same thing. It's gotten so ba that it wit even shift into 2nd gear. When I went to pull the shift shaft it wouldn't slide out. Gonna have to cut it. I'd say your having the same issue start with the shift shaft
    chubbs's Avatar
    Apr 2009
    Southwick
    What does the bike have for a clutch? Sometimes having more then 4 clutch springs will do this
  7. #7
    klx110 lover:)'s Avatar
    Aug 2012
    maryland
    Quote Originally Posted by dbramper223 View Post
    You shouldn't have to cut your shift shaft out... Mine didn't move when I went to pull it so I took off my shift lever and with a couple taps with a hammer it came out.
  8. #8
    May 2011
    Vermont
    Quote Originally Posted by klx110 lover:) View Post
    I tried tapping it out. Didn't want to budge. I have t taken it out yet tho. It's actually on a friends bike and he hasn't come up with any money so i haven't spent too much time. Il try again tho
  9. #9
    Feb 2013
    Quote Originally Posted by chubbs View Post
    It's a stock semi auto clutch with 6 springs 3 ard hd tho
  10. #10
    chubbs's Avatar
    Apr 2009
    Southwick
    Run only 4 clutch springs and see if the problem persists.
  11. #11
    Aug 2012
    maryland
    Ohh okay wasn't sure if you tried that. Maybe just use a rubber mallet and give it a few good wacks, but not crazy wacks lol
  1. Gear on Secondary Clutch / Primary Drive Gear Question
    By racemx100 in forum KLX110, DRZ110, TTR90
    Last Post: 08-25-2009, 02:20 PM
  2. wanted for 110:4th gear drum,lightweight primary gear,cradle mount
    By redirt78 in forum Bikes and Parts Wanted - All Makes
    Last Post: 06-26-2009, 12:41 PM
  3. dodgy backyard video
    By madmick in forum KLX110, DRZ110, TTR90
    Last Post: 10-26-2008, 03:19 PM
  4. Replies: 2
    Last Post: 06-26-2008, 09:17 PM
  5. troy lee 08 gear, thor gear, goggles and helmet! FOR SALE
    By muuurph in forum Misc Items for Sale
    Last Post: 05-26-2008, 09:20 PM
dodgy 3rd
