Best upgrade for KX65 forks?
This is a discussion on Best upgrade for KX65 forks? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Hello, I am 190lbs and want to get my 2002 and 2003 kx65 forks upgraded. What would be the best upgrade for somebody my size ...
Results 1 to 8 of 8
    Lschreur's Avatar
    Nov 2005
    Hello,
    I am 190lbs and want to get my 2002 and 2003 kx65 forks upgraded. What would be the best upgrade for somebody my size and where can I get it done (I was planning on shipping the forks off to get the work done)? Presently the forks are stock. (one set will go on a klx 110 and the other will stay on a kx 65)
    Also, I have a 2002 KX65 that I was thinking about updating. Is there a shock anybody knows of that would work for my fat ass? I went to the kawasaki dealer and he did not have any ideas.
    Final question. Does anybody know where I can get a set of quality fork springs for a 2005 KX250? My dealer was able to order a Race Tech shock spring, but could not find a set of fork springs. I need something stiffer than stock.
    Thanks and Regards, Lon..
    2005 Thumpstar Pro
    2004 KLX 110
    2005 Pitster Pro
    2005 CRF 70 w/bbr 88 big bore
    2005 CRF 70 w/AHP Stage 3 w/auto clutch
    Also several big dirt bikes
    mad 110's Avatar
    Sep 2005
    internet chat rooms
    [quote name='Lschreur']Hello,
    dude oh yeah for the kx65 forks go with the manitou works cartridge kit in both of them theirs nothing out that can touch them.they blow circles around zocchi their like $450.00 installed thru pax racing but if you get both sets done don (owner of pax) will cut you a deal call him at 818-897-0373 between 9am & 5pm and tell him Que told you to call about these kits if you go to factory connection they will doe it but for $750.00 each. call don at pax and he will tell you the real on these kits. also you can go to www.paxracing.com to look at the kit. under suspension.
    mtbracer's Avatar
    Mar 2005
    Playa Del Rey, CA
    I am 190 and run Minibike 65 springs with 20 wt oil. I like the step up and it's very easy to install. springs are available from motohp
    MotoHP 180 W/SuperHead, KX65 Forks, Oil cooler, SIK EXT long travel swing with Elka Shock, and lots of other stuff.
    foxrider868's Avatar
    Aug 2005
    If you wanna go all the way, get the manitou fork kit from factory connection.
    http://www.factoryconnection.com/index2.htm
    go to products, then mini products then scroll down and its right there.
    2006 klx110
    Pro Circuit t-4
    Two Brothers tall seat
    Maguara Hydraulic Clutch
    BBR Shift Lever
    2004 Xtreme CR107 FOR SALE!!!
    12" wheels, two bros brake lever, green plastics, michellin tires, Renthal Grips, RK gold chain.
    mtbracer's Avatar
    Mar 2005
    Playa Del Rey, CA
    The manitou fork kit is an excellent kit, but $450.00 The spring kit is only $90.00 and add 20wt oil and you save the rest of your money for other parts.
    SClow303's Avatar
    Dec 2005
    Mansfield, Ohio
    I just got off the phone with the MotoHP guys. I ordered the aggressive 65 springs. What a nice group of guys to deal with! Thanks for the tip MTBRacer.
  7. #7
    mad 110's Avatar
    Sep 2005
    internet chat rooms
    Quote Originally Posted by mtbracer
    yeah you can go that way to but just dont ride nobodys 110 with the manitou kit on them cuz you will be kicking youre self in the arse later whishing you had got those kits,I had the springs and they worked ok till I got the manitou kits installed and i was like dam what a world of difference, i even sold my zochhi after that for $900.00
  8. #8
    110racer180's Avatar
    Jan 2005
    yea if u wanna pend alot of money bring them in somewere and get them all set up for you ... that would be the best way to go but more expensive
Remove Ads
best upgrades for kx65
kx 65 fork upgrade
kx 65 fork upgrades
kx 65 suspension upgrades
kx 65 upgrades
kx65 fork springs
kx65 fork upgrade
kx65 fork upgrades
kx65 suspension upgrade
kx65 suspension upgrades
kx65 works cartridge
pitster pro forks on kx65
