my 2004 klx 110 wont go into 3rd gear. it grinds when i try for 3rd.
This is a discussion on my 2004 klx 110 wont go into 3rd gear. it grinds when i try for 3rd. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; hi guys, i just bought the bike (klx 110 2004) and after i got it running, it was sitting for about 6 months, i took ...
Results 1 to 6 of 6
    is vexed
    chetty mo's Avatar
    Nov 2013
    hi guys, i just bought the bike (klx 110 2004) and after i got it running, it was sitting for about 6 months, i took it out for its first ride and 1st and second is fine but when i try for 3rd.... grind grind grind and it acts like a neutral or it just wont go all the way into 3rd. if i pull up hard with my hand it kind of tries for 3rd but slips right out. i took off the side with the clutch and inspected the star but it seemed ok. also when its sitting still, engine off, it will only shift into first and back down into neutral.something just not right, any ideas what might be the problem. thanks in advance.
    is living the american dream!
    KlxRacer#2's Avatar
    May 2010
    we scrub harder in Ohio!
    sounds like shift drum
    2010 BBR 50
    2011 BBR v3
    2004 Honda Cr125
    2015 Piranha 190
    2015 Gorilla 190
    2015 Trail 70
    Thanks to Wholesale-Cycle, TB Parts and BBR Motorsports
    is vexed
    chetty mo's Avatar
    Nov 2013
    Quote Originally Posted by KlxRacer#2 View Post
    do you have to split the case for that.?
    KlxRacer#2's Avatar
    May 2010
    yes
    2010 BBR 50
    2011 BBR v3
    2004 Honda Cr125
    2015 Piranha 190
    2015 Gorilla 190
    2015 Trail 70
    is Walter White
    BTF_Tundra's Avatar
    Jan 2013
    SoCal
    Quote Originally Posted by chetty mo View Post
    No just take the oil cap off and add water. Should fix the problem.
    dbreid's Avatar
    Aug 2011
    Milwaukee, WI
    Nice ALOL!!
  1. Stuck in gear and wont start?
    By supernowa260 in forum Chinese/Import Minis - General Discussion
    Last Post: 05-08-2013, 07:28 AM
  2. Klx 110 Wont Go Into Any Gear
    By gixxerkid101 in forum KLX110, DRZ110, TTR90
    Last Post: 03-27-2011, 06:58 PM
  3. HELP! takegawa 3 speed wont go into gear
    By jyoung in forum CRF50
    Last Post: 07-09-2010, 09:25 PM
  4. Who grinds cam profiles
    By notme in forum Chinese/Import Minis - General Discussion
    Last Post: 11-25-2008, 08:01 PM
  5. wont go into third gear
    By hoerter2158 in forum KLX110, DRZ110, TTR90
    Last Post: 10-10-2008, 08:05 PM
2004 klx 110 just popping into gear
2006 klx 110 wont go into third gear
drz 110 not sparking not going into gear
klx 110 not going into 3rd gear
klx 110 wont shift into neutral
my klx 110 wont shift to 3rd
