2012 KLX 110L - turn back to auto clutch question
This is a discussion on 2012 KLX 110L - turn back to auto clutch question within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a taller kid for his age and bought a 2012 KLX 110L. He can ride with clutch in fields but when we get ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree1Likes
Thread: 2012 KLX 110L - turn back to auto clutch question
    moomoo's Avatar
    Aug 2015
    I have a taller kid for his age and bought a 2012 KLX 110L. He can ride with clutch in fields but when we get in tight woods and such, he is struggling. I see where they make kits to turn the automatic clutches into semi automatic, but wondering what I need to take the manual to be semi automatic (still have clutch lever but have automatic to prevent stalling).
    Looking at diagrams, it looks like I could replace the long collar (#13097 part) with a centrifugal clutch housing and clutch assembly on the crank assembly.
    Part numbers appear to be the same going back to atleast 2003, however when I see people with the centrifugal clutch housing and clutch assembly for sale on ebay and other sites, they always say 2003-2009.
    Just wondering if anyone has done anything similar or has suggestions (besides make him learn the clutch...).
    Thanks in advance.
    Ls1
    Ls1 is offline
    is ""You live more in 5
    minutes at those speeds than
    most men do in a
    lifetime" - Burt Munro
    Ls1's Avatar
    Feb 2012
    Bellevue, Ohio
    Maybe look up the parts diagram for the 2012 non L model and see what's different/what you need to go full auto. Not sure about keeping the clutch. That can be done, people have done it - but all of them started with a semi auto bike and added the clutch, not the other way around. As fast as kids grow and advance, I fear he would have/could have figured the clutch out before you "Figure the clutch out". On the other hand you don't want the little guy to get frustrated and not want to ride either. If it were a quick fix as in - Add this part = your problems solved...I'd say go for it. But this is a little tougher - Gonna be up to you.
    2010 110L Custom plastics/graphics to be Honda CR tribute bike. 143 stroked to 155, TB V2 head, 28mm carb, tb intake, U flow, Yosh RS2 pipe, KX65 front forks/brakes, red baron triples, pro taper 110 bend bars, tbr OTT, Foes Racing +3 swingarm
    speedy mendeavel's Avatar
    Sep 2011
    PA
    I'd say the time and money to do it wouldn't be worth it because once you do it the kid will probably learn how to use the clutch just fine.
    Just let him ride in the fields for a little more seat time and he'll get it down no problem.
    234wheeler likes this.
    pitbikeman's Avatar
    Jun 2006
    Gallipolis, Oh
    I've got everything you need I'd sell cheap
    I would like to thank the following:
    fst96se's Avatar
    Apr 2015
    I've been interested in this as well. I have a daughter that rides a 2012 klx110, and I have a 110l for me to play around on.
    She fits the height of the L much better, but really isn't ready for s clutch.
    fst96se's Avatar
    Apr 2015
    Any more thoughts on this?
  7. #7
    moomoo's Avatar
    Aug 2015
    Sorry for delay in update. Yes I was able to do this. The bike now is like a rekluse clutch. Had to spend about $300. From Kawasaki I order the automatic clutch assemebly and bearings. The stock clutch cover does not work because 1.) the automatic clutch assemble it too large 2.) the clutch arm coming into the stock case is coming in at wrong angle so had to buy the case and clutch cable from Tbolt. Son loves it for woods riding as he never has to worry about stalling in a race. I prob can find exact part list if you need.
  8. #8
    Dirtbikedad's Avatar
    Dec 2016
    I'm wanting to do the same thing for my daughter. Could you post a parts list? Please and thank you.
  9. #9
    Dec 2016
    I decided to try this on my own. I'll update when I get the parts.
  10. #10
    is Playing catch up like it was
    08 to a dying mini scene
    FMFHATR799's Avatar
    Jan 2016
    Fontana, California
    What did you do with the parts you took off? Anyone have inout if they will fit on older bottom ends?? Shouldnt be different ?
    15 PIRANHA 190
    12 KLX110L
    05 DRZ110
    93 Z50R
    02 Z50R CLONE
  11. #11
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    Ehhh. According to BBR, you'd likely have to go to the all up shift pattern on the non L model to go to the centrifugal clutch. I'd have him keep working with the clutch and he'll get it eventually. Or get an older 110 to ride until he's big enough to get the clutch on the L. --L*64
  12. #12
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    You can just add the centrifugal clutch with a aftermarket manual clutch cover and it will work similar to a rekluse. The sift drum only needs changed if your trying to do a complete semi auto swap Iike a non L or older models.
  13. #13
    Dec 2016
    Just completed this swap. Ordered a used (good shape) centrifugal clutch and housing from ebay, and a tbolt manual clutch kit(cable style). The autoclutch works great. The clutch pull is quite a bit harder.
  14. #14
    Dec 2016
    Sorry, I plan to keep my L parts.
  15. #15
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    Quote Originally Posted by Dirtbikedad View Post
    The pull is very hard on them. Tbolt use to have a clutch perch/lever that made it a easier pull, not sure they still have it. Also fly racing makes a easy pull lever assembly too
    Edit. Here it is
    http://tboltusa.com/store/ez-pull-po...ch-p-8095.html
  1. Replies: 6
    Last Post: 12-29-2014, 08:08 PM
  2. Converting 110L To Auto Clutch
    By ducncover in forum KLX110, DRZ110, TTR90
    Last Post: 01-04-2012, 02:38 PM
  3. From Manual clutch back to auto clutch problems!!
    By motocrosspunk199 in forum KLX110, DRZ110, TTR90
    Last Post: 03-02-2009, 02:03 PM
  4. Replies: 4
    Last Post: 02-21-2009, 02:44 PM
  5. Have SL70 clutch turn back to auto?
    By dhanson96 in forum CRF50
    Last Post: 01-21-2004, 07:33 PM
klx 110 l auto clutch
klx 110 semi auto clutch
klx 110l have a semi auto clutch
