KLX110 or TTR125 aftermarket fuel screw?
This is a discussion on KLX110 or TTR125 aftermarket fuel screw? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I'm changing the jets and working with the fuel screws on my boys' bikes and can't find aftermarket fuel screws that are hand-adjustable. Anyone know ...
Results 1 to 5 of 5
    bmiliate's Avatar
    Feb 2006
    I'm changing the jets and working with the fuel screws on my boys' bikes and can't find aftermarket fuel screws that are hand-adjustable. Anyone know where I can buy them?
    Thanks.
    bmiliate's Avatar
    Feb 2006
    bump
    bump
    DAGNER's Avatar
    Mar 2005
    South of Heaven,FLA
    Most air screws are a strigt screwdriver fitting. turn the screw all the way in and then back it out 2 full turns. Start there
    bmiliate's Avatar
    Feb 2006
    Thanks Dagner.
    xr88honda's Avatar
    Sep 2005
    circleville ohio
    if you want a finger adjustable air screw just make one with a small piece of sheet metal and two part epoxy,cut the metal into the desired shape and stick it in the groove and epoxy it in,hell ive been doing that since the late 90s,works great and is a lot cheaper,but you might get some laughs by the boys,but who cares[poor men have poor ways]haha good luck
    go put your halloween costumes on while mom hides the easter eggs
2006 klx 110 fuel screw problem
2006 klx125 fuel screw
fuel screw location on ttr 125 2006
klx 110 fuel screw
klx 125 aftermarket fuel screw
klx 125 fueal screw
klx110 fuel screw
ttr 125 aftermarket fuel screw
ttr 125 fuel screw
ttr 125 fuel screw adjustment
ttr 125 fuel screw setting
ttr125 aftermarket
