Front sprocket help/questions
This is a discussion on Front sprocket help/questions within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Picked up an engine that did not have a front sprocket on it. There is a collar behind the sprocket that goes into the seal ...
Results 1 to 2 of 2
    Harmon237's Avatar
    Nov 2006
    Bakersfield, CA
    Picked up an engine that did not have a front sprocket on it. There is a collar behind the sprocket that goes into the seal on the output shaft.
    Does this lookcorrect? I don't have another bike to check for reference at the moment.
    is Leaning heavily towards
    unloading some minis.
    elixur's Avatar
    Dec 2007
    Washington
    Yes, it spaces it out so your chain don't chew up the case. As long as you can fit the snap ring on to keep the sprocket on ur good.
    It shows the collar/bushing on the microfiche in the transmission section.
  1. Piranha 140 front sprocket / gearing questions
    By モンキ in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-01-2013, 08:41 PM
  2. A few chain/sprocket questions..
    By mxracer41 in forum CRF50
    Last Post: 11-17-2009, 03:01 PM
  3. ////// Cold Fusion 34t and 35t sprocket, Takegawa 15t front sprocket, more....
    By cmktech in forum KLX110/Midsize Parts for Sale
    Last Post: 05-11-2008, 07:42 PM
  4. a few questions???counter shaft sprocket, main sprocket, chain.
    By alcapon1 in forum KLX110, DRZ110, TTR90
    Last Post: 04-02-2007, 06:39 PM
  5. Sprocket questions
    By jmurray192 in forum 1988 ZB50 and ZB Import Replica Bikes
    Last Post: 12-08-2006, 03:29 PM
