stock pb18 carb pilot airscrew question
This is a discussion on stock pb18 carb pilot airscrew question within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a stock 2012 KLX110L and from looking at the carb the pilot air screw is either blocked/capped off or is there a special ...
Results 1 to 6 of 6
    sbmon's Avatar
    Jun 2014
    ATL GA
    I have a stock 2012 KLX110L and from looking at the carb the pilot air screw is either blocked/capped off or is there a special tool needed to adjust? The brass looking top looks like possibly a plug. Does this plug need to be drilled out to adjust/reach the head of the actual pilot air screw?
    Thank you
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    The microfiche diagram shows the air screw, spring, and o-ring, I would think if it was plugged off, they wouldn't show the part in the fiche as being available.
    2012 Kawasaki KLX110L (KLX110DCF) Carburetor | Babbitts Kawasaki Partshouse
    - dirtbkr188 -
    sbmon's Avatar
    Jun 2014
    ATL GA
    Yes I too looked at the same carb parts diagram. I know I have another bike (suzuki) that from the factory the pilot fuel (not air though) screw was blocked off with a brass plug that can easily be drilled out. I didn't want to go drilling here though without confirming what may be here. Surprised this is not mentioned anywhere in these forums? I am just looking to fine tune with a posh pipe I have installed.
    sbmon's Avatar
    Jun 2014
    ATL GA
    So the consensus is the pilot airscrew is is covered or fixed (no adjustment range)?
    GSully23's Avatar
    Jan 2017
    are you talking about the brass adjustment needle that sort of has a D shaped cap? if so that is not a plug/cap. there is a special tool to adjust it, but what I did was backed it out with a pair of needle nose pliers far enough that I could take a dremel and notch it so I could use a flat head screw driver to adjust further. manual calls for 1 1/4 turns out stock. I can snap a pic when I get home from work
    GSully23's Avatar
    Jan 2017
    here's a quick pic if you can relate to it. FYI this is off my 2008 klx110.Click image for larger version.
  1. stock klx carb pilot jets
    By ryan2282 in forum Vendor Area - Wanted
    Last Post: 12-08-2010, 03:50 PM
  2. Stock carb pilot jets
    By ryan2282 in forum KLX110, DRZ110, TTR90
    Last Post: 12-06-2010, 05:19 PM
  3. Stock carb Pilot jets ????????????
    By BUGGZ in forum KLX110, DRZ110, TTR90
    Last Post: 03-11-2009, 02:21 PM
  4. 42 pilot jet for stock carb?
    By Luckystar64 in forum KLX110, DRZ110, TTR90
    Last Post: 06-10-2008, 09:31 PM
  5. fs keihn pb18 carb setup for 50
    By slapaho16 in forum CRF50/CRF70 Parts For Sale
    Last Post: 07-30-2006, 02:23 PM
