KLX 110 Street tires for kart track - Need help on sizes
This is a discussion on KLX 110 Street tires for kart track - Need help on sizes within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have used the search function and haven't been able to find the information I am looking for. Seems like a lot of the older ...
Results 1 to 14 of 14
    Subaruzi's Avatar
    Jan 2016
    I have used the search function and haven't been able to find the information I am looking for. Seems like a lot of the older threads have links to tires that are no longer on that particular site if the site is still active. Here is my question:
    What size tires (width/height) can I run on the 14" stock wheel without any modification?
    What size tires (width/height) can I run on the 12" stock wheel without any modification?
    Answer can be in following format if it is easiest: 80-120 width / 60-100 height or however you want to post it. I am assuming that the width is my biggest hurdle to start.
    Thank you in advance.
    Subaruzi's Avatar
    Jan 2016
    Will a 110 fit the rear?
    Sent from my SM-G900V using Tapatalk
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You may have a hard time getting the bead to seat properly on the stock 1.60" rear rim
    - dirtbkr188 -
    Subaruzi's Avatar
    Jan 2016
    Weird thing is these guys say 120 can fit: KLX110 CRF 70 DRZ 110 REAR STEET TIRE IRC SS540 Rear Street tire
    Seems way too wide to me.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quote Originally Posted by Subaruzi View Post
    I have to agree, especially with the smaller sidewall aspect ratio. Maybe they are referring to the fact that it may fit inside the stock swingarm
    - dirtbkr188 -
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    you can run a 120 on the rear but if your going to use the stock 1.6 wheel it will be tough to get the bead to set and will pinch the tire which changes the profile of the tire. If your going to use the stock wheel I would go with the 100/90, I cant recommend anything for the stock 14 front as I have never ran a 14/12 setup only 12/12. I would highly recommend contacting Kevin and gatorrimz and get a 12/12 setup which will get you 2.15 front and a 2.5 rear, bt that does depend on your budget and what you plan on doing with the bike.
    TMGP #78
    TEAM I JUST WANNA RIDE #104
    Come Out & Join Us Hidden Content
  7. #7
    Subaruzi's Avatar
    Jan 2016
    Quote Originally Posted by rob78 View Post
    I'm in touch with Kevin and will probably (95% sure) get a set of Gatorrimz but I am looking to get son set up quick and inexpensive for the time being and then get the wheels when I've got a bit more cashflow.
  8. #8
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    if I remember correctly the kx60 rear wheel is the same spoke count as the klx front wheel so if you could locate a kx60 rear wheel the hoop will lace up to the front klx hub giving you a 12/12 setup, not ideal but a cheap option
    TMGP #78
  9. #9
    Subaruzi's Avatar
    Jan 2016
    So just finished using stock rims. I might do a quick write up under another post for people interested.
    IRC NR77 on the front. Easy change, went on with very little issue
    Dunlop TT93 GP Front Tire - 100/90-12 on the rear. Wild pain in the neck to get on. I spent about an hour and half trying to get on before breaking down and going to local shop.
  10. #10
    Subaruzi's Avatar
    Jan 2016
    I have 32 hole hoop I'd like to put front hub on. Need to get correct spokes though.
  11. #11
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You're probably going to have to send the hoop and hub to Buchanon to have custom spokes made up
    - dirtbkr188 -
  12. #12
    jstrong394's Avatar
    Oct 2010
    Not many options for the 100/90-12. Would a 110/90 work? I have been wanting to order some dirt track style tires. What size is being used for the 14" front
  13. #13
    Subaruzi's Avatar
    Jan 2016
    I'll have to tell you later as I can't remember. Super narrow though. Maybe an 80
  14. #14
    Subaruzi's Avatar
    Jan 2016
    Here's tire exactly: http://www.50stunt.com/mobile/Product.aspx?id=818
  1. PW80 on kart track - need help with tires and wheels
    By Subaruzi in forum Mini-Motards
    Last Post: 01-28-2016, 04:48 PM
  2. Tires for a sealed asphalt kart track
    By jstancel in forum Mini-Motards
    Last Post: 12-21-2015, 02:36 PM
  3. 10" street tires on stock rims...what sizes are you using??
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 07-16-2012, 08:31 AM
  4. Klx 110 Street Tires
    By kylechristensen in forum Stunt Minis
    Last Post: 05-11-2011, 02:16 PM
  5. Klx 110 Street Tires
    By kylechristensen in forum KLX110, DRZ110, TTR90
    Last Post: 03-16-2011, 05:09 PM
