What's this sound? KLX 110 front wheel
This is a discussion on What's this sound? KLX 110 front wheel within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; https://youtu.be/fudFHQs9JpE Sent from my SM-G900V using Tapatalk...
Results 1 to 9 of 9
    Subaruzi's Avatar
    Jan 2016
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Maybe you missed inserting the front axle through the center spacer in between the wheel bearings?
    Part #92027 shown here
    - dirtbkr188 -
    Subaruzi's Avatar
    Jan 2016
    You think I could get axle through? Other thing I need to add is I haven't tightened the axle. Sounds might go away if I tighten?
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You can try that, but if the center spacer isn't in place on the axle, you will put undue pressure on the wheel bearing centers, and eventually the bearings will collapse.
    - dirtbkr188 -
    Yagatogi's Avatar
    Apr 2015
    Cali-AZ-LV
    Just a guess but maybe uneven brake shoes from being worn? My brothers klx had this sound and it was worn and we loosened the brake to where it didnt engage at all even when lever was pulled but noise went away. Replaced brakes and now it doesnt make any noise.try it might be the same issue.good luck
    Subaruzi's Avatar
    Jan 2016
    I'm more inclined to go with uneven brake wear. I can't imagine I could get axle through and miss spacer. My experience with spacers is that if they're there you have to go through them properly or the axle won't go through
  7. #7
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Well, it was an irregular tinny sound, like metal-to-metal, and only when you spun the wheel forward. Can't think of anything else that would be rolling around in there, unless a wheel bearing is bad and it's a loose bearing plinking on the axle spacer.
    - dirtbkr188 -
  8. #8
    Yagatogi's Avatar
    Apr 2015
    Cali-AZ-LV
    Again not saying im right but Reason why it could be the shoes making that sound is cause it could be lightly catching pad and vibrating the spring that hold the shoes.atleast thats what we found on my brothers.
  9. #9
    Subaruzi's Avatar
    Jan 2016
    I'll pull wheel and check both. Appreciate the help.
  1. klx 110 12" front wheel/brakes black excel rim 2012 klx110L front forks
    By dylancordell in forum KLX110/Midsize Parts for Sale
    Last Post: 07-16-2014, 08:15 PM
  2. klx 110 rear wheel AND disc brake for zokes front wheel
    By Petersen114 in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-10-2013, 06:33 PM
  3. Klx 110 front forks & front wheel
    By 2009klx110man in forum KLX110/Midsize Parts for Sale
    Last Post: 09-23-2012, 04:19 PM
  4. Replies: 0
    Last Post: 06-14-2011, 08:17 PM
  5. KLX 110 Front Complete Front Wheel $35
    By GregP in forum KLX110/Midsize Parts for Sale
    Last Post: 05-30-2009, 09:07 PM
