are these even ktm 65 forks I bought, they were shortened, but how?
This is a discussion on are these even ktm 65 forks I bought, they were shortened, but how? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; so as some of you might have read I bought a 07 65sx parts bike to swap the front end over to my 110. One ...
Results 1 to 5 of 5
    GSully23's Avatar
    Jan 2017
    so as some of you might have read I bought a 07 65sx parts bike to swap the front end over to my 110. One fork tube was damaged, and I found another set of forks on eBay that had the anodized tubes, and the adjustable C&P like the first gen zokes, with the 65 lower lugs on it. the owner said they came on the bike and had been shortened about 2 inches and included the spacers for the rear shock to make it match. I assumed when I opened up the forks i would find a spacer, but I didn't see any. I ordered new he springs for my weight and the spring is 5/8 of an inch longer than the old one.
    my question is, does this assembly look anything like first gen zokes inside. I have only opened up the compression side as of now. The upper tube diameter and length is the same, the lower tube diameter is the same, and it has 65 lugs on the fork stantions.
    now keep in mind I have another set of 65sx forks if I need to swap to them, just curious if that will be the case. I have also yet to remove the stantions and upper tube for separate measurements but id feel the internals should be able to speak for them self.
    here's some pics
ID:	204289   Click image for larger version.
ID:	204297   Click image for larger version.
ID:	204305   Click image for larger version.
ID:	204273   Click image for larger version.
    GSully23's Avatar
    Jan 2017
    well I got the one fork leg together, it actually wasn't too bad but the springs are pretty tight inside the tube. I just did a test fit and pushed them through there stroke without oil and I could hear slight squeaking. I'd like to sand and polish the springs to clean them up a little bit and hopefully make the fit a little less tight and smooth. I had read somewhere else that others have had there first gen zokes squeak for the first few hours of use.... anyone else experience that?.
    and has anyone ever tried media blasting springs and then polishing them? or anyone else have any experience polishing springs for use?
    GSully23's Avatar
    Jan 2017
    so as you know I pulled the forks apart. I didn't separate the uppers and lowers, but did remove the cartridges. No spacers found anywhere. ordered the HD 5.0kg springs for my weight and they were a tight fit. I ended up sanding them with 80,240,400,600, and finished with 1500. springs slid in like butter. overall very happy with the results, but still is less travel than stock or first gen zokes and I can't figure out where I'm losing it.
    I'm compared my OE M ktm65sx forks cartridge to these cartridges and they are the same length. So where am I losing the travel, cartride/dampening rod is the same length, so is the upper fork tube, as well as the springs.....where am I losing the 1.5" of travel at?
    GSully23's Avatar
    Jan 2017
    well there coming aling. front brake is together, polished triples, new pads, rebuilt the caliper. the thing feels great. just waiting on my front end bearing conversion from pax to put them on and than next up is the motor. I want to be able to hit some of the stuff on the big bike track with this bad boy so looking to bore and stroke to a 178cc or a 194cc. there's the perfect step up with my name on it I've had my eyes on. I definitely do need a cradle mount as well. motor build is up and coming in the next few weeks.
    GSully23's Avatar
    Jan 2017
    have them installed, waiting for the new yoke but to come in to set the bearings. also order a newer 2012 wave rotor to slap on because I notice mine was slightly warped. should be sick. now I'm onto the motor. hoping to get s 194cc going on in there, th v2 head, head, decompression option, stroke crank, 28mm carb, and rearward racing intake. should be quite the bike to rip.
  1. Showa 85 forks shortened for 110
    By SchlauchMx in forum Feelers and What is my bike/parts worth?
    Last Post: 01-22-2013, 11:27 AM
  2. Shortened Showa 85 forks
    By SchlauchMx in forum KLX110/Midsize Parts for Sale
    Last Post: 01-17-2013, 03:43 PM
  3. i just bought a conversion kit for my klx to put ktm forks on
    By lightle09 in forum KLX110, DRZ110, TTR90
    Last Post: 06-21-2010, 10:18 PM
  4. CR85 Forks shortened and made to fit 70 frames etc
    By Rossbikekingmx in forum KLX110/Midsize Parts for Sale
    Last Post: 09-24-2008, 07:37 PM
  5. ktm 65 front talon billet hub to fit your ktm forks
    By ddk1 in forum CRF50/CRF70 Parts For Sale
    Last Post: 06-11-2006, 08:30 PM
