KLX110 aftermarket carb recommendations?
This is a discussion on KLX110 aftermarket carb recommendations? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a 2009 KLX110 that I am looking for an aftermarket carb for. Everything is currently stock and I don't imagine doing anything outrageous ...
Results 1 to 2 of 2
    duck1973's Avatar
    Mar 2017
    I have a 2009 KLX110 that I am looking for an aftermarket carb for. Everything is currently stock and I don't imagine doing anything outrageous to it. The bike had a Chinese carb on it and never runs the same. I had another KLX110 that I swapped its stock carb to and the bike ran great so I know the bike runs fine.
    What aftermarket carbs do you all recommend for a bone stock bike? I may upgrade exhaust later but not as of now.
    Thanks!
    Ls1
    Ls1 is offline
    is ""You live more in 5
    minutes at those speeds than
    most men do in a
    lifetime" - Burt Munro
    Ls1's Avatar
    Feb 2012
    Bellevue, Ohio
    If your only mod is to be an exhaust - get a stock carb. It will actually serve you better than an aftermarket or a bigger one. There is an abundance of them around. If you go with a pipe you may have to adjust main jet size but that's it.
    2010 110L Custom plastics/graphics to be Honda CR tribute bike. 143 stroked to 155, TB V2 head, 28mm carb, tb intake, U flow, Yosh RS2 pipe, KX65 front forks/brakes, red baron triples, pro taper 110 bend bars, tbr OTT, Foes Racing +3 swingarm
  1. aftermarket klx110 exhaust and carb
    By kawasaki304 in forum Bikes and Parts Wanted - All Makes
    Last Post: 02-12-2010, 02:00 PM
  2. Carb recommendations. . .
    By Sideways717 in forum KLX110, DRZ110, TTR90
    Last Post: 04-02-2008, 07:00 PM
  3. 110 motor/carb recommendations...
    By anyonebut_24 in forum KLX110, DRZ110, TTR90
    Last Post: 06-04-2007, 11:29 PM
  4. Carb Recommendations for BBR 82cc Kit
    By casean in forum CRF50
    Last Post: 02-10-2005, 06:12 PM
  5. Cam carb jetting recommendations for 82cc
    By klimaxx in forum CRF50
    Last Post: 01-21-2005, 10:58 PM
