05 DRZ 110 Carb question
This is a discussion on 05 DRZ 110 Carb question within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; So found this sub $400 fixer, guy said it had high idle and didn't have time to mess with it. Looks like it is missing ...
Results 1 to 1 of 1
    Lucy1nsky's Avatar
    Apr 2017
    VA
    So found this sub $400 fixer, guy said it had high idle and didn't have time to mess with it. Looks like it is missing parts where the throttle cable meets the carb? Besides that it had no chain and a flat rear, so I have chain sprockets and tube otw.
    Also replaced the super long throttle cable that was on it. So I'm wondering if I just order the missing carb pieces and then do an idle tune if I should be good to go. Anything else i should check out or look for?
ID:	207393   Click image for larger version.
ID:	207401   Click image for larger version.
  1. WTB DRZ/KLX 110 big bore motor/carb
    By xxmustang281xx in forum Bikes and Parts Wanted - All Makes
    Last Post: 02-21-2014, 07:21 PM
  2. klz/drz 110 peg mount question
    By coby110 in forum KLX110, DRZ110, TTR90
    Last Post: 08-16-2013, 01:41 PM
  3. Klx drz 110 exhaust question
    By uriham23 in forum KLX110, DRZ110, TTR90
    Last Post: 01-10-2013, 06:27 PM
  4. DRZ-110 BigBore/Clutch Question...
    By gabeherndon in forum KLX110, DRZ110, TTR90
    Last Post: 01-20-2010, 10:06 AM
  5. 110 carb question
    By MpR in forum CRF50
    Last Post: 06-22-2005, 07:14 PM
