Ticking sound klx 110
This is a discussion on Ticking sound klx 110 within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; My klx 110 pitbike is making a ticking sound that started after i had the rear tire off for a patch. It gets louder has ...
Results 1 to 5 of 5
    Tokerus's Avatar
    Apr 2017
    My klx 110 pitbike is making a ticking sound that started after i had the rear tire off for a patch. It gets louder has the bike comes to a stop. It sounds like very fast ticking or clicking and seems to come from under the engine cover by kick start. Any help would be great.
    GSully23's Avatar
    Jan 2017
    not to sure where your saying the sound comes from, is it near the kickstarter or near the head? it's possible maybe your kickstarter isn't disengaging all the way.....or maybe your valve lash is out of does? just guess though......hard to tell without being there to see it in person
    Tokerus's Avatar
    Apr 2017
    Its hard to tell myself because it was only happening during acceleration, now it happens during acceleration and gets louder has the bike idles down.(also occasionally shuts bike off)
    But it sounds like it comes out directly behind where you pour in oil.
    Background on my klx:
    .2007
    .has hit the ground a few times but nothing serious.
    .Sprocket teeth are worn
    . im 150lbs.
    .Probably never had its engine cleaned, oil filter changed, valves, etc.
    .i have changed the oil.
    Tokerus's Avatar
    Apr 2017
    My 07 klx110 is making a ticking sound that now gets louder has the bike idles down.
    Its hard to pinpoint where its coming from.
    Its probably never had the oil filter, valves or anything besides the oil cleaned/adjusted.
    Tokerus's Avatar
    Apr 2017
    Klx110 Ticking
    2007 klx110 is making a Ticking sound and now gets worse has bike idles Or brakes are applied. I believe everythings orginal on it and probably never adjusted. Ive changed the oil and patched the rear tires innertube and the ticking started after i put the rear wheel back on. Please help
  1. yx 160 ticking sound from clutch area?
    By rawdog in forum Chinese/Import Minis - General Discussion
    Last Post: 01-27-2015, 09:22 AM
  2. klx 110 ticking noise
    By dehn257 in forum KLX110, DRZ110, TTR90
    Last Post: 03-18-2012, 09:58 PM
  3. Rebuilt Klx Ticking Sound Video
    By sixsicsix19 in forum KLX110, DRZ110, TTR90
    Last Post: 07-29-2011, 10:32 AM
  4. Ticking/Clicking sound from engine
    By arlindsay1992 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 11-18-2007, 08:32 PM
  5. Ticking/Clicking sound from engine
    Last Post: 11-18-2007, 10:49 AM
