Klx 110 stripped oil filter bolt threads
This is a discussion on Klx 110 stripped oil filter bolt threads within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Getting ready to do a helicoil on my oil filter threads and want to confirm if the correct heli coil kit is m6x1? Already have ...
Results 1 to 10 of 10
    efiles123's Avatar
    Aug 2012
    Getting ready to do a helicoil on my oil filter threads and want to confirm if the correct heli coil kit is m6x1? Already have the kit but the coils in the package seem loose on the bolt.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Once you've drilled the hole out with the right size drill bit and re-tapped the hole with the right size tap, you'll find that the bolt will be snug after you've installed the heli-coil in place.
    M6 x 1.0 is the correct size
    - dirtbkr188 -
    efiles123's Avatar
    Aug 2012
    Thats what I thought. Can you remember what size drill bit to use?
    dirtbkr188's Avatar
    May 2004
    New Jersey
    I'll have to look in my Heli-Coil kit tomorrow to get the drill bit size for you.
    - dirtbkr188 -
    efiles123's Avatar
    Aug 2012
    Sounds good! I appreciate the help.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    It takes a 1/4" drill bit for the M6 x 1.0 Heli-Coil
    - dirtbkr188 -
  7. #7
    efiles123's Avatar
    Aug 2012
    Awesome thanks. Looking forward to fixing it this weekend.
  8. #8
    efiles123's Avatar
    Aug 2012
    Got the heli coil in and it's a little crooked it still works fine. The coil is angled downward. Everything still came together fine and no oil leaking. Has anyone else had a coil go in crooked? Maybe the holed wasn't bored straight?
  9. #9
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quite possibly the tap threaded in at a slight angle after you drilled it out?
    - dirtbkr188 -
  10. #10
    efiles123's Avatar
    Aug 2012
    Could be
  1. threads on the YX oil filter housing?
    By Beavinator in forum Chinese/Import Minis - General Discussion
    Last Post: 09-20-2014, 10:44 AM
  2. thread stripped from oil filter cover
    By ktmsx 125 in forum KLX110, DRZ110, TTR90
    Last Post: 12-25-2010, 12:18 AM
  3. Stripped threads on case
    By weihl165 in forum Honda CRF70
    Last Post: 05-22-2010, 02:26 PM
  4. HELP Stripped oil cooler bolt :(
    By Zmnypit in forum Chinese/Import Minis - General Discussion
    Last Post: 01-21-2008, 06:03 PM
  5. stripped threads
    By NIKLP4 in forum KLX110, DRZ110, TTR90
    Last Post: 07-06-2005, 07:22 PM
