Big bore head torque problems
This is a discussion on Big bore head torque problems within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Since installing the TB parts V2 head and 67mm big bore cylinder & piston, my head bolts keep coming loose and causing a head gasket ...
Results 1 to 3 of 3
    Greenfz1's Avatar
    Jun 2016
    Since installing the TB parts V2 head and 67mm big bore cylinder & piston, my head bolts keep coming loose and causing a head gasket leak.
    The head bolt studs have now started to pull out of the cases - (one of which had to have a timesert installed.)
    Has anyone else experienced this ? And any solutions ?
    Any feedback or suggestion is welcomed
    Thanks
    tmas's Avatar
    Apr 2005
    TO
    Just a suggestion...I remember reading about the HD studs a while ago from BBR.
    BBR Motorsports, Inc - Products
    Greenfz1's Avatar
    Jun 2016
    Quote Originally Posted by tmas View Post
    Thanks for sharing Tmas-
    Didn't know BBR made those -
    The bored cases cases seem to be the weak link in my situation
  1. klx110 big bore problems
    By kawi143 in forum KLX110, DRZ110, TTR90
    Last Post: 02-26-2012, 01:23 PM
  2. Problems With Trailbikes Big Bore
    By modmobber in forum KLX110, DRZ110, TTR90
    Last Post: 04-14-2011, 10:22 PM
  3. Torque specs on big bore installation.
    By jsmith811 in forum KLX110, DRZ110, TTR90
    Last Post: 04-12-2007, 09:55 PM
  4. Big Bore Kit Problems
    By xulcuz in forum CRF50
    Last Post: 10-10-2006, 08:14 PM
  5. big bore problems
    By badkippy in forum CRF50
    Last Post: 10-22-2005, 09:44 AM
