KLX Won't Start?
KLX Won't Start?
This is a discussion on KLX Won't Start? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Hello, I have a 2011 klx110 that doesn't want to start. Last year after a wash it would die when I turned the throttle and ...
Results 1 to 6 of 6
    is 2010 klx110 Stock Mod
    SikkMx108's Avatar
    Sep 2011
    Long Island, NY
    Question KLX Won't Start?
    Hello, I have a 2011 klx110 that doesn't want to start. Last year after a wash it would die when I turned the throttle and starting it turned into a pain. A few days later when the bike dried, it ran fine. For a while it sat so I drained the gas, cleaned the carb and checked all the wire connections. It doesn't want to start period. I have a DMM and tested the coil which weren't matching factory specs. I borrowed my friends klx110 coil, but still no signs of life. Where should I go from here? The bike has spark and the plug is a nice tan. Should I change it anyway? I'm unsure where to go from here. It definitely is an electrical issue.
    SikkMx108's Avatar
    Sep 2011
    Long Island, NY
    Anything?
    is Almost ready
    Imback's Avatar
    Aug 2009
    Buena Park Ca
    do the light on the big e-start come on. if not check the fuse on he left side of the bike.
    SikkMx108's Avatar
    Sep 2011
    Long Island, NY
    Quote Originally Posted by Imback View Post
    Yes I checked all fuses and the electric start light comes on when I kick the bike over.
    GSully23's Avatar
    Jan 2017
    check your kill switch. I had the same issue, turned out to be the kill switch
    is Leaning heavily towards
    unloading some minis.
    elixur's Avatar
    Dec 2007
    Washington
    U can check the kill switch by un plugging it and use a wire to connect the 2 wires out of the engine harness. If it runs it's ur kill switch if not ur kill switch isn't the problem.
    Having said that, if u have spark I wouldn't think it's the kill switch.
  1. Klx 110 won't start or bump start
    By Kilmer4qb in forum KLX110, DRZ110, TTR90
    Last Post: 03-09-2016, 12:53 PM
  2. Klx 110 won't start??
    By DirtBikeDan296 in forum KLX110, DRZ110, TTR90
    Last Post: 05-18-2015, 09:50 PM
  3. 2003 RM60 won't start / hard to start
    By dhumphus in forum 2 Stroke Pitbikes
    Last Post: 08-25-2013, 12:05 AM
  4. 09 Klx 110 Won't Start
    By GAM3R in forum KLX110, DRZ110, TTR90
    Last Post: 04-25-2011, 02:36 PM
  5. Replies: 10
    Last Post: 06-19-2009, 09:51 AM
