Do they bolt right up the stock clamp on a drz 110?
This is a discussion on Do 1991 rm 80 forks work? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Do they bolt right up the stock clamp on a drz 110?...
Not sure.....if there is somewhere to get a measurement, with "calipers" in mm's, that will tell you. Have you researched any of the Suzuki parts websites? You can find the micro fiche parts breakdowns on the net, and usually they will give the fork size/dimensions. Good luck.
i dont think they will..i believe they are too big. i have a set of 1985 rm80 forks that bolted right up. i also believe the 91s will have a disk brake system so you need to deal with that too
JF 262
are you selling the 1985 ones or no?
ha no sorry..i pry made it sound like that but im not as of right now
JF 262
darn! do you like the forks? and what are you running in the rear? Do you know anyone selling 80 or 60 forks?
i love the forks..they are way better than the kx 60 ones. they give you more travel and more bottom control. i have a stock rear end and i need an extended swinger real bad..i am choppered out pretty bad. ha so let me know if you know of anything to help me out. im looking at the billetware +4 with an elka or an f22 ishock
josh
JF 262
I was curious about that also what years of the kx/rm 80 forks will work ?
Also can you use the hubs as well I read somewhere that the brake shoes are the same for 60s and 80s ???
Anyone have a kx 65 front wheel I can buy ?
Str8ryder76@yahoo.com
Im think it 79 or 80-85. Not sure about 79 tho. They bolt right up. One guy had to grind the brake tab down a lil bit.
(A True MX'er)
If your bikes worth more than your car.
You see perfect berms and jumps everywhere you go.
http://www.myspace.com/136899806
05 Xtreme CR2
99 XR70R
99 Z50R
Thanks
