Need Help!
This is a discussion on Need Help! within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I drilled out the pipe in my klx 110 and have a two brothers filter with an 85 main and 40 pilot when i let ...
Results 1 to 11 of 11
Thread: Need Help!
    mike307's Avatar
    Oct 2006
    Need Help!
    I drilled out the pipe in my klx 110 and have a two brothers filter with an 85 main and 40 pilot when i let off the throttle and hit it again it bog's out and almost stall's out. Whats wrong and what should i do?
    mike307's Avatar
    Oct 2006
    Nobody Knows!
    kawasakifan700's Avatar
    Jul 2006
    I had kinda the same problem as you and i fiddled with the air/fuel mixture and it helped. I think i made it a little richer.
    What Is It About Driving Cars That Makes You All Such A$$holes.
    Kill One Person... Your A Murderer
    Kill One Million... Your A King
    mike307's Avatar
    Oct 2006
    this probally sounds stupid but do i have to take the carb off and apart for the air/fuel mixture
    Jul 2006
    nope, if ya look on the right side of the bike there are two little screws. One that faces straight out and one that kinda faces up. The one that faces up is the air/fuel mixture, and the one the faces straight out is the idle. If you have the manual that came with the bike it should have it in there. If ya want me to take a picture i will.
    mike307's Avatar
    Oct 2006
    i think i no what ur talkin about but how do u turn it, it looks like theres nothin to turn?
  7. #7
    mike307's Avatar
    Oct 2006
    i got it to turn thanks kawasakifan700
  8. #8
    motox92's Avatar
    Jan 2006
    Buxton,Maine
    i had that same problem so i mut the stock airbow on and it runs like a dream now
  9. #9
    Jul 2006
    hey mike, is it runnin better?
  10. #10
    boondocks's Avatar
    Apr 2006
    Make sure your float valves working correctly which you removed to replace the jets.
  11. #11
    mike307's Avatar
    Oct 2006
    ya its running better than thanks
