I was looking into a better intake manifold for the stock head to vm26 carb. Does anyone know if I could use a KITACO intake for the SE head and then match the stock head to it. Or any other suggestions?
This is a discussion on Intake for VM26 and stock head within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I was looking into a better intake manifold for the stock head to vm26 carb. Does anyone know if I could use a KITACO intake ...
2005 KLX110
KX65 forks w/ BRP clamps
Metaltek swinger w/ F22 I-shock
Tak 138 Stage 3 kit
KX65 wheels and brakes front and rear
I have what you are looking for
would you have pic'sOriginally Posted by Motarded
trailbikes has both intakes for stock head and racehead.
I have a tak intake for stock head, but I wanted to get a better shaped intake and then have the head ported to match.
What do you have?
2005 KLX110
Tak 138 Stage 3 kit
The Kitaco manifold will bolt on. They make two versions, one for stock head, one for the SE head.
Every one makes two versions, TB, Takegawa, and Kitaco. I dont care for the Take ones. I would go with the TB intake for stock head.
Thanks to:
Thumpstar - for the factory ride
FMF
Cat 5
T Bolt USA
TBparts.com
SG Racing
Velocity Works Suspension
"Jetster220 (1138 PM): Mike is the man"
Founder of the "Fl Mullisha" ... FL chapter
I would go with the Kitaco intake, shorter intake manifold.. Takegawa/TB are too long for me.
MotoHP 180 W/SuperHead, KX65 Forks, Oil cooler, SIK EXT long travel swing with Elka Shock, and lots of other stuff.
Originally Posted by mtbracer
The TB intake is extremely short!
^^^ It looks like the same bend as the tak one.....
2005 KLX110
Tak 138 Stage 3 kit
