110 questions
This is a discussion on 110 questions within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; im thinking about buying a 110. i want to get fastminis pipe some kind of swingarm and shock. if i get a billet ware what ...
Results 1 to 5 of 5
Thread: 110 questions
    yamaha's Avatar
    Jul 2006
    locust grove, va
    110 questions
    im thinking about buying a 110. i want to get fastminis pipe some kind of swingarm and shock. if i get a billet ware what forks and shock do i need.
    motox92's Avatar
    Jan 2006
    Buxton,Maine
    i just got a pitboss swingarm with the racetech extended shock which is the same as the metaltek swingarm and it is a extremely nice set up
    Pitrcer3's Avatar
    Mar 2005
    Harrisburg, PA
    if you go with the billetware swingarm i'd go with some sort of set up other than the stockers...low end you can do dampening rods, oil, and spacer, medium you can do like a kx60 front end and slide the forks up through the clamps alittle if you have to.(i just got a set of kx60 forks and deciding on rear end as we speak) and high end there are lots of options kx65, sx65 forks with PAX or BRP clamps or the zokes too. I am thinking of doing a billetware, or sik110's swingarm with the iShock...
    50vs110's Avatar
    Oct 2006
    Classic has a pimp new swingarm setup..2 diff styles....you should check them out.
    Pitrcer3's Avatar
    Mar 2005
    Harrisburg, PA
    yea that new CHP stuff is amazing...looks soo nice too i wish i had a grand to drop on that..
