how to kick a modded klx110 - Page 4
This is a discussion on how to kick a modded klx110 within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; so it doesnt have to be in between gears, or have the clutch pulled in? u can just kick it in gear and it starts? ...
Page 4 of 4 FirstFirst ... 234
Results 46 to 49 of 49
Like Tree1Likes
Thread: how to kick a modded klx110
  1. #46
    xxmustang281xx's Avatar
    Jul 2012
    Daytona Beach, FL
    so it doesnt have to be in between gears, or have the clutch pulled in? u can just kick it in gear and it starts? how is this any better for the bike than kickstarting it in neutral, if ur still using the kickstart? someone explain to me a little better the correct way to kick it over in neutral. push down easy until it gets harder to push, then kick it hard from there?
  2. #47
    mxnut23's Avatar
    Apr 2011
    I'd like to know how to bypass that anti-bumpstart device. My klx is an 07 with a tb manual clutch kit. Is it normal that when I pull the clutch in the kicker won't turn over the crank?? When I put it into neutral and leave the clutch out bike will start. Other than the manual clutch the bike is stock.
  3. #48
    mxnut23's Avatar
    Apr 2011
    Nevermind on the bumpstart info, I finally found The search icon in the PM app. Lol. But the clutch thing is a little weird though.
  4. #49
    Jeffrey Dennis's Avatar
    Feb 2013
    I have a problem. I have a klx 110 and the left vent hose fell off. Does anybody know where it goes? It's the same size as the carb bowl drain hose? Runs in between the shifter and through the cylinder fins. Where up top does it attach with the spring clip?
2006 klx110 hard to start when hot
can u start a klx with the clutch pulled in
can you jump start a klx 110
klx 110 hose size
klx110 143 hot start
klx110 143 problems
klx110 bump start
klx110 bump start device
klx110 hard start when hot
klx110 hot start
modded klx110
my klx 110 kicks right through
