KLX rear set up help needed
This is a discussion on KLX rear set up help needed within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I am building a KLX for my 8 yr old. Running KX65 front end and the KX65 rear with disk set up on the stock ...
Results 1 to 17 of 17
    Briovalley's Avatar
    Jul 2006
    I am building a KLX for my 8 yr old. Running KX65 front end and the KX65 rear with disk set up on the stock swingarm. Works great, but after jumping.... and bottoming out, he complains that his back hurts.... dang kid. I am trying to avoid dumping another 1k into this thing, because I have not started on the motor yet. Does anyone have suggestions (or for sale) on what swingarm/shock combo would work and not thin my wallet out to bad. He weighs about 65 lbs.
    Oh, does it need to be a long travel? Would a +3 swingarm be good? I want to make sure that whatever I run, brings the rear up a few inches. One last thing, is the Red Barron 290 mm shock an option with other companies swingarms?
    Thank you for the help.
    Briovalley's Avatar
    Jul 2006
    MiniRacer33's Avatar
    Jan 2006
    Thousand Oaks, CA
    red baron doesnt make that shock anymore.....they have the Fox Float MXR shock.
    team RB4L- www.myspace.com/RB4Lminis
    BIG MINIS, Pax Racing, JB graphics, TNP Racing, Marzocchi, Spy Goggles, SGR Usa, Red Baron, Renthal, Osiris Shoes, Acerbis
    "You couldn't catch air if you fell out of a plane" -Kevin Skene (MiniRacer101)
    www.sponsorhouse.com/members/sean33
    www.myspace.com/sean33
    Jan 2006
    Thousand Oaks, CA
    Drowe's Avatar
    Nov 2006
    Charlotte, NC
    I have 65 forks and a sik110 swinger with elka and it feels real good. But yea, a +3 would be fine. I dropped the forks an inch up front and it evened out the bike height wise.
    Drowe's Avatar
    Nov 2006
    Charlotte, NC
  7. #7
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    Brio could u post some pics? What do you need to run this setup on the stock parts? Just some custom mounts for the calipers?
  8. #8
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
  9. #9
    Drowe's Avatar
    Nov 2006
    Charlotte, NC
    Talk to tnpracing on here and he will hook you up with 65 rear brake mounts and stuff.
  10. #10
    Drowe's Avatar
    Nov 2006
    Charlotte, NC
  11. #11
    slapaho16's Avatar
    Apr 2006
    Fort Worth TX
    i would try a fox float shock by far the most adjustable shock on the market
    Riding 50s and slappin hoes
  12. #12
    slapaho16's Avatar
    Apr 2006
    Fort Worth TX
  13. #13
    TLDRIDER120's Avatar
    Mar 2006
    houston texas
    ya same here as drowe.. but cheap forks.. kx 60 just as good but cheaperr.. i think there just agood.. sikk 110 +3 and elka is GREAT just shock is soo much $$ ahhh... hey DROWE i got that torque arm.. its perfectttt i love ittt... only comes in black but it still looks gooddd has some silver on it... if u ever wanttt one give sikk a call
  14. #14
    Mar 2006
    houston texas
  15. #15
    Briovalley's Avatar
    Jul 2006
    I'll post some pics when I figure out how to do it. The rear only required fabing a mount for the master. The rear wheel/caliper assem fit great into the stock swingarm. I works for the purpose of having the disk on the rear, but the stock suspension is junk. I think I'll try a +3 with the fox shock. It sounds like the Sik110's is the way to go.
    Is anyone out there running the KX65 wheel/caliper assem on one of thier swingarms? Do they offer one with any fab work to help hold the caliper?
    Thnx
  16. #16
    Briovalley's Avatar
    Jul 2006
    Thnx
  17. #17
    Salmon's Avatar
    Apr 2004
    Fort Collins, Colorado
    I run a Foes +4 swingarm with a KX65 wheel and brake setup. Works pretty good so far. I run the I-shock extended shock and it has plently of travel.
2006 kx65 suspension setup 65lbs
