85 main jetting klx110 did nothing? need help!!
This is a discussion on 85 main jetting klx110 did nothing? need help!! within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I got a 85 main jet for my 07 klx110 and it looks no different then my stock one. I was going to put a ...
Results 1 to 6 of 6
    alcapon1's Avatar
    Nov 2006
    san diego
    I got a 85 main jet for my 07 klx110 and it looks no different then my stock one. I was going to put a 40 pilot but they gave me the wrong size. I can feel no difference, maybe a little better throttle responce in the early revs but I really dont know. Any advice? . I have a Yoshi exhaust and uni high flow filter and I cant seem to get it to stop backfiring when letting off the throttle on the high revs, PLEASE HELP ME
    Calif-klx110's Avatar
    Sep 2006
    San Jose, CA
    Did you change the exhaust gasket on the Yosh pipe or use the stock one. My son's 05' did the same when we installed the Dr. D. Turned out the exhaust gasket was old and was leaking causing air to be sucked in.
    Motodad's Avatar
    Oct 2006
    If it is backfiring when chopping the throttle, you have an exhaust leak.
    adumb's Avatar
    Mar 2006
    Plymouth, MA
    Quote Originally Posted by Motodad
    or a lean jetting condition
    Trick Daddy's Avatar
    Jun 2006
    Loves Park, IL
    Most likely an exhaust leak. You should have the bigger main installed and definitely the 40 pilot if the airbox is removed. The 42 will not run right.
    Jun 2006
    Loves Park, IL
    I'd just get rid of the airbox. I ran a stock 110 with the airbox installed and I preferred the stock filter element. I got a little bit of popping on decel, but only up in the very top of the rev range....typically right on throttle chop...with stock jetting. No running issues and no engine damage...
85 main on klx 110
deceleration backfire klx110
klx 110 85 main jet
klx 110 lean jetting backfire
klx 110 stock jet 85
klx110 85 main 40 pilot
main jet klx110 yosh exhaust
