Help - Gas pouring out of overflow on carb.
This is a discussion on Help - Gas pouring out of overflow on carb. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just picked up an 05 drz110 last night. Some guy bought it for his daughter and she crashed so bike has been sitting for ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Steak Taco's Avatar
    Jan 2007
    Chandler, Arizona
    I just picked up an 05 drz110 last night. Some guy bought it for his daughter and she crashed so bike has been sitting for a while. So today I strip down plastics and clean everything, dump out old gas, drain float area of carb which had some almost rust looking crud in one corner that I got out. Well I put everything back together and it started up on second kick but I look down and gas it leaking out of overflow from float are in a steady stream. Any ideas what is causing this? As soon as you turn petcock on it starts coming out.
    fifty_tony's Avatar
    Aug 2006
    SoCal
    Floats are sticking
    Steak Taco's Avatar
    Jan 2007
    Chandler, Arizona
    How do I fix?
    Waiting for pipe to cool before I take it apart.
    supermanseatgrab's Avatar
    May 2006
    Lenox, MA
    gotta take the carb apart and see if the floats are not centered....usually playing with the tab will allow it to not stick
    Warning: The Surgeon General says its OK! to SMOKE the competition
    '04 SDG #187
    Steak Taco's Avatar
    Jan 2007
    Chandler, Arizona
    Thanks for help guys. Took it apart and messed with it and it still had a little drip. So I took it up and down street a couple times and it stopped. I don't know how or why but it seems to be right.
    927DAD's Avatar
    Jan 2007
    Maryland
    Turn the fuel off and drain the fuel bowl then spray WD40 in inlet to the carb that should fix your problem. I do it has mantanice on the bikes,4wheelers, and the Jr. Dragster
  7. #7
    mxer122's Avatar
    Jan 2007
    i usually hit the bowl with a hammer gently
  8. #8
    927DAD's Avatar
    Jan 2007
    Maryland
    The problem is usually in the needle and seat . You said the was rust in the fuel bowl.
  9. #9
    mtnbykracr's Avatar
    Aug 2006
    Gilbert, AZ
    I agree with 927DAD, there's usually just a tiny grit that holds the needle open, it will keep the gas pouring into the bottom of the carb. You will need to clean all that crap out. Check your gas tank too. I had an old XR70 that sat and the tank was FULL of GUNK! I kept cleaning the carb just to have it fill up with gunk from the tank. Good luck! Hey, I need to meet you, you are only a few miles from me. I think you've met John who is also on this site. Need to go out riding soon!
    Moto HP 180 Monster +R race head with some BBR Stuff, Marzocchi stuff etc - fun bike!
  10. #10
    Brent878's Avatar
    Dec 2005
    Southern California
    Quote Originally Posted by 927DAD
    the needle shouldn't make the gas come out of the over flow. the float is what controls the gas coming from the tank. Like if your bike is off and you turn your throttle wide open gas doesn't come out of overflow becuase the float is not moving.
    If it starts leaking again you might have bent the tabs on the float when you were cleaning it so the foat activates too early. Sounds like you got it fixed but if it keeps happening you can just bend the tab alittle so it doesn't do it as often.
    2006 Reeg 70
    2003 XR50
    2004 CRF50
    2003 CR250
    2002 CR125
  11. #11
    Steak Taco's Avatar
    Jan 2007
    Chandler, Arizona
    One of the things I did the last time I took it apart was bend that little tab up and it seems to have worked no more problems.
    Mtnbykracr, ya we need to meet and go out riding one of these days. I got some stuff coming fedex today to make my bike more comfortable, pegs, seat, etc.. but I still need to beef it up some to hang with your bike. That thing must be super fun to ride.
  12. #12
    mtnbykracr's Avatar
    Aug 2006
    Gilbert, AZ
    Understand about the float but if the float is working fine, it's connected to the needle/seat and it doen't matter if the float is all the way up, if there's grit where the needle and set is, gas will continue to pour in there...
  13. #13
    mtnbykracr's Avatar
    Aug 2006
    Gilbert, AZ
    Hey Steak, ya, it's really fun but if you ask Sonquizzon, he'll tell you that it's too scary!!!!
  14. #14
    mtnbykracr's Avatar
    Aug 2006
    Gilbert, AZ
    Brent878, I meant the needle and seat not the needle on the slide, sorry!
  15. #15
    Brent878's Avatar
    Dec 2005
    Southern California
    Quote Originally Posted by mtnbykracr
    no problem, maybe i just mis understood. I was thinking needle on the slide. But you are right on the seat part.
    2006 Reeg 70
    2003 XR50
    2004 CRF50
    2003 CR250
    2002 CR125
Remove Ads
04 klx 125 carb leaking
2005 kawasaki klx 110 gas running out of overflow tube
2005 klx 125 carburetor leaking
crf50 carb dumps gas
drz 125 leaking fuel
drz 125l carburetor leaks
i have gas pouring out of over flow line
is it normal for fuel to come out of overflow when bike is rock on a 2005 cr250r
my ttr 50 leaks gas when gas is on and parked
sdg 125 leaking fuel out of carburetor
ttr 90 carb dripping gas
ttr 90 yamaha gas leaking from carb overflow
