Chain slack with extended shock?
This is a discussion on Chain slack with extended shock? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; After my first day out at the kart track I decided that I needed to raise the bike up a bit after dragging my pegs ...
Results 1 to 8 of 8
    matttys's Avatar
    Dec 2006
    Columbus, Ohio
    After my first day out at the kart track I decided that I needed to raise the bike up a bit after dragging my pegs in every corner. My bike is on the budget and I do not want to buy a new shock, forks, etc (but I have upgraded to heavy springs front and rear). My buddy made a nice 1" shock extender that fits the stock swing arm and shock. It raised the bike significantly, but now I am concerned about how much slack I should be running in the chain. When the bike compresses there will become less slack as the swing arm passes through horizontal. How much slack should I run. Previously I was running 1 to 1.5".
    matttys's Avatar
    Dec 2006
    Columbus, Ohio
    Any ideas? I'm teaching my girl friend how to ride on the 110 and would like to get her out this evening as the weather is going to be great. Any help would be appreciated!
    jthenderson669's Avatar
    Sep 2006
    Danville, IN
    well, the best way to determine what you need is to take the shock out and raise your swingarm up to put axle level with the plane of the bike, this should be your tightest spot, so as long as its not overly tight there you are good. hope this helps.
    Jay Tee
    bobbob1015's Avatar
    Feb 2005
    Malone N.Y.
    If its too tight i just tighten it up more and jump up and down on it in hope of stretching the chain...
    1. Remove shock
    2. Lower back of bike
    3. Check chain tension
    4. In all positions (chain is tighter some places then others, when rolling bike)
    5. Replace shock
    6. Go show that biznatch how to ride.
    *HONDA 117*, marz forks, Black rims ,IRC and starcross, fox air, + 4 SANO swinger
    matttys's Avatar
    Dec 2006
    Columbus, Ohio
    Sounds good. I didn't know if any one had nuggets of wisdom that didn't involve me taking the shock off again, but that sounds like my project for the evening. Thanks guys!
    2wheeltyson's Avatar
    May 2005
    michigan
    depending on how much you weigh, i always check mine while sitting on it. it helps to have 2 people.
  7. #7
    Mxracer6's Avatar
    Mar 2006
    Oklahoma
    Quote Originally Posted by 2wheeltyson
    so longs as you get the swingarm parallel - it doesnt matter how you do it
    -- have somebody sit on the bike while you check it --
    Thanks to: Ray Fine Yamaha, One Industries, Fly Racing, SteelMX, Motoworld.com
  8. #8
    stik__boy's Avatar
    May 2005
    wisconsin
    wlgkjwklgjw
    push on the bottom part of the chain with your finger, if your finger hits that tab that your chain guard thingy bolts to, you're good. i've been roadracing these things for 3 years now... and it took awhile to find a find a good safe way to tell.... thats it.
3 pit bike shock extender
are shock extenders safe
crf50 extenders
crf50 shock extender
crf50 shock extension
does the rear pit bike shock extender go on top or bottom?
klx110 shock extender
pitbike shock extension
raised shocks chain slack
ttr 90 extender
ttr-90 shock extender
ttr90 extender
