clutch springs
This is a discussion on clutch springs within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; 65 or heavy duty springs ?...
Results 1 to 10 of 10
Thread: clutch springs
    NIKLP4's Avatar
    Mar 2005
    PITTSBURGH PA.
    clutch springs
    jthenderson669's Avatar
    Sep 2006
    Danville, IN
    Re: clutch springs
    moto hp claims to be 40% stiffer than any other "stiff" spring, but i heard that 65s are even stiffer.
    Jay Tee
    mtbracer's Avatar
    Mar 2005
    The 661 / 714
    Re: clutch springs
    The MotoHP springs are the same rate as the 65 springs, but with the correct spring height.
    MotoHP 180 W/SuperHead, KX65 Forks, Oil cooler, SIK EXT long travel swing with Elka Shock, and lots of other stuff.
    xr1million's Avatar
    Dec 2005
    Just south of hell, FL
    Re: clutch springs
    65...
    Thanks to:
    Thumpstar - for the factory ride
    FMF
    Cat 5
    T Bolt USA
    TBparts.com
    SG Racing
    Velocity Works Suspension
    "Jetster220 (1138 PM): Mike is the man"
    Founder of the "Fl Mullisha" ... FL chapter
    Mx356's Avatar
    Nov 2005
    TX
    Re: clutch springs
    Get the MotoHP springs
    Paxracing's Avatar
    Mar 2004
    ca
    Re: clutch springs
    we sale 10 sets a week of kx 65 springs for the klx 110.
  7. #7
    Cali110's Avatar
    Dec 2006
    Riverside, CA
    Re: clutch springs
    Quote Originally Posted by Paxracing
    Congradulations
  8. #8
    millbillyfiddy's Avatar
    Dec 2003
    Cape Cod Mass
    Re: clutch springs
    I have the Mottohp springs and they are stiff enough for my big bore klx
    MotoHP150+R with 55mm crank
  9. #9
    fiddy64's Avatar
    Nov 2006
    Tulsa, OK
    Re: clutch springs
    get minibikesprings.com clutch springs. He uses a better wire and they will not fade.
  10. #10
    lumpdog256's Avatar
    Sep 2006
    Oklahoma
    Re: clutch springs
    cannonracecraft.com springs are made of stainless steel and are heat set so they do not shorten.....great company
    Cannon RaceCraft the Springmaker
    CannonRacecraft.com
    Performance Coatings
    405-525-9790
    Oklahoma Honda-Suzuki
    OKHonda-Suzuki.com 405-672-1423
    Relentless
    BShipman Films
    DZGraphicsmx.com
    JESUS
