Does anyone have the Specs on the PE28 Keihin carb????
This is a discussion on Does anyone have the Specs on the PE28 Keihin carb???? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Looking to see if anyone knows the following: Main jet size needed: Pilot Jet size needed: Needle jet/Emulsion tube # stamped on it??: Needle number ...
Results 1 to 14 of 14
    siktendenciesracing's Avatar
    May 2007
    Los Alamitos, CA
    Needle number stamped on the needle??:
    and any other words of advice about tunning this carb.
    NOTE: i have a PE 28 carb that came off of a CR80.
    Thanks, and I appreciate your help
    May 2007
    Los Alamitos, CA
    Re: Does anyone have the Specs on the PE28 Keihin carb????
    Also my Needle # in the carb is the following:
    24NAAJ
    Banned
    HACKMUNCH's Avatar
    Apr 2006
    BRUNSWICK OHIO
    39 Pilot,95 Main For Scut 178.
    flyn62's Avatar
    Nov 2006
    maple valley
    im wondering the same thing. do u need to change the needle to get it to run or is the one on the stock 80/85 carb fine?
    May 2007
    Los Alamitos, CA
    What about the Needle number and the Emulsion tube?? I know that the CR/YZ/KX are different and one is good and one is bad for this application,,, I have the CR,,,, is that the right one???
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    I wanna say the suggestion from Hack before was for the KX needle.
  7. #7
    May 2007
    Los Alamitos, CA
    Quote Originally Posted by HACKMUNCH
    What cam are you guys running on the 178+R kit???
  8. #8
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    I have a brand new PE28 from Tak that I just got for my 124+R if those specs do you any good?
    The older I get, the faster I was !
  9. #9
    Banned
    HACKMUNCH's Avatar
    Apr 2006
    BRUNSWICK OHIO
    kx needle and stock atomiser. s 20 cam.
  10. #10
    May 2007
    Los Alamitos, CA
    Quote Originally Posted by FastMC
    That would be awesome,,, please share numbers on that carb, I would love to know what Takagawa's carb has in it cause there 26mm carb is the best to jet out of all the other 26's
  11. #11
    Kurlon's Avatar
    Feb 2005
    Southern Maine
    Ok, so I hit up Ron Ayers and got Kawi PN 16009-1958 for the needle, 16017-1365 for the emulsion tube. Are those the parts to get Hack or did I use the wrong bike? (2000 KX80)
    If that, along with a 39 pilot are all thats left to dialing in the PE28 on my 151... that'd rock.
  12. #12
    is full of gas !
    FastMC's Avatar
    Mar 2004
    boston area
    This is a PE28 from a Tak kit# 03-05-098
    Slide number = 2TE 60
    Needle # F1343H 24NAAC
    No # on nozzle and oddly no bleeder holes along the sides.
    Came standard with #35 pilot and #110 main.
    Dont know if it helps but some more info in the mix.
  13. #13
    Banned
    HACKMUNCH's Avatar
    Apr 2006
    BRUNSWICK OHIO
    that sounds right kurly.
  14. #14
    May 2007
    Los Alamitos, CA
    is the Takagawa 50 carb kit with the PE28 the same exact carb as the one for the KLX110???
Remove Ads
carburetor keihin pe28 pilot jet
keihen pe28 spec
keihin pe 28 carb spec
keihin pe 28 emulsion tube
keihin pe 28 specs
keihin pe28 carburetor
keihin pe28 factory specs
keihin pe28 needle
keihin pe28 spec
keihin pe28 specs
pe 28 keihin specs
pe28 keihin slide
