KLX110 clutch help please
This is a discussion on KLX110 clutch help please within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Hey guys, a buddy of mine has a 110 whose clutch is slipping pretty bad, and I suggested a heavy duty auto(he doesnt want to ...
Hey guys, a buddy of mine has a 110 whose clutch is slipping pretty bad, and I suggested a heavy duty auto(he doesnt want to go manual or hydraulic)and I cant find an entire kit like TB offers for the Hondas, whats the deal with that?Anyhow, if i was to install just plates and springs(aftermarket) would it eliminate this slipping?Also does anyone have instructions on how to?Thanks
11-26-2007 06:24 PM
Re: KLX110 clutch help please
Put HD springs in it & adjust it correctly
Originally Posted by
blue44
There are quite a few companies that offer clutch plates and heavy duty springs.
Basically replace that what you take out and most hd springs use 6 instead of the stock 4.
Make sure you soak the plates with oil before you install them other wise you'll glaze them and have to start over.
Just get a KX65 clutch kit from ebay or from paxracingstore.com, the one Pax sell are just a KX65 kit.
If sticking with auto you don't want all 6 KX65 (heavy duty) springs, you only want to install 3 of them and 3 brand new stock KLX springs. If you go 6 HD springs it will be super hard to shift.
- You may not post replies
- You may not edit your posts
Forum Rules
adjusting drz 110 clutch
ajusting clutch on klx 110
how to adjust clutch on klx 110
how to adjust cluth on klx 110
how to adjust klx 110 clutch
how to adjust the clutch on a klx 110
klx 110 adjusting clutch
klx 110 clutch springs
klx 110 with clutch kit doesnt shift properly
klx110 clutch help please
klx110 heavy duty clutch plates
tighten clutch on klx 110
