165 + 55mm cam recommendation
This is a discussion on 165 + 55mm cam recommendation within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; i am running motohp 64mm racegas piston,pitboss crank,tb race head,26mm carb,Inner rotor ign,only using tb cam that came with head.what are some good cams that ...
i am running motohp 64mm racegas piston,pitboss crank,tb race head,26mm carb,Inner rotor ign,only using tb cam that came with head.what are some good cams that will work good with this setup?any dyno #'s for diff cams?i know there must be a cam that will work better with this set-up.also where will i be able to buy these cams?thanks in advance
11-30-2007 01:32 AM
Re: 165 + 55mm cam recommendation
get a diff head if u want more power......+R is the way to go...
i am going to stay with this head for now,just want to find the best cam for mid/top end power.
Originally Posted by
jrotten
For such a big engine, I'd recommend getting a 28mm carb. TM, PE, PWK doesn't really matter. They take some messing with, but so does any other carb.
As for Camshafts, yer kind of limited because with the size of the valves and such, there isn't really enough room for a cam with more lift and duration.
You can't really add more overlap. (well ya can, but for the money that you would spend on a new cam, it's not gonna make that big a difference.)
Takegawa's (non +R ) cam seems to work fairly well, but you'll have to check all your clearances.
whats the best place to but the Tak cams?,also what about crower,do they make anything?any others?i know the +r is the best,but this is what i have for now,and besides one of the guys i work with has a flow bench,and he is good wih improving velocity,so this is what i am going to work with first
jrotten
be leary of what happens on a flow bench. Just like a dyno. What happens on those machines doesn't necessarily make it good for the track.
Anybody can produce good flow and or velocity numbers, just like showing good numbers on a dyno, but it doesn't mean it will be fast nor ridable.
that's just my opinion.
As for where you can get that Takegawa cam, there are plenty of shops out there that will be willing to sell you cams. Crower you can call directly.
thanks for the response,i understand about the flow numbers.but this guy has a long history of producing real/usable numbers.our shop just had him bild some stock class machines for bonneville,zx14,rocket3,-and we set two records,so i a feel confident in his ability.on the crower web site i didn't see any klx camshafts-did i miss something?
- You may not post replies
- You may not edit your posts
Forum Rules
55 mm camshafts
