I-Shock Chain Rubbing
This is a discussion on I-Shock Chain Rubbing within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just installed an ishock on my 110 and i noticed that the chain is rubbing on the swingarm because the extended shock has made ...
Results 1 to 11 of 11
    punkguitarist's Avatar
    Oct 2004
    I just installed an ishock on my 110 and i noticed that the chain is rubbing on the swingarm because the extended shock has made the swingarm sit at more of an angle.
    has anyone else had this problem? any ideas how to fix it?
    thanks
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    Re: I-Shock Chain Rubbing
    Rubbing where? The chain slider?
    Oct 2004
    hmm just realized theres no chain slider on my stock 110 swingarm. i never realized there is suppose to be one.
    it rubbing on the part where the swingarm pivots on the frame
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    You need a chain slider then. That is normal for longer shocks.
    Oct 2004
    it seems like even with a chain slider it would be rubbing way too much because of the angle of the swingarm with the extended shock.
    so this doesn't cause any problems?
    skudster351's Avatar
    Dec 2007
    Rome, GA
    just tighten the chain some. Just move the rear axel back a couple notches till its where you want it.
  7. #7
    357 Racing's Avatar
    Dec 2006
    Austin, Texas
    What length did you get?
  8. #8
    Banned
    ROBINSONDB22's Avatar
    Feb 2007
    KILLumbus, oHELLo
    chainging the angle of the swinger is the only way to get the chain to not rub so aggressively try loosening the shock spring so it is not as long that is all you can do unless you change the swingarm and a slider is a must the chain will rub that swinger till you can't change it then you'll have to cut it off
  9. #9
    Z70AK2's Avatar
    Oct 2005
    Have you got a smaller than stock front sprocket? We had a similar problem when we swapped to a 13 tooth sprocket.
  10. #10
    Oct 2004
    Quote Originally Posted by crf150r
    this is the 275mm/crf70 length shock.
  11. #11
    Oct 2004
    i just checked the gearing and its 13 tooth c/s and a 33 tooth rear sprocket. is this stock gearing?
chain rubbing on swingarm of ttr 110
chain rubs on swingarm on ttr 90
klx110 swingarm chain rubbing problem
shock spring rubbing on chain
ttr 90 chain rubbing frame
yamah ttr 110 chain rubbing
