Clutch adjustment on KLX
This is a discussion on Clutch adjustment on KLX within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Does anyone know how to adjust the clutch and what is the standard adjustment? Thank you for any help!!...
Results 1 to 9 of 9
    Shrank Daddy's Avatar
    Nov 2007
    Warshingtun Stayt
    -eagle-'s Avatar
    Apr 2004
    Southern Ohio
    Re: Clutch adjustment on KLX
    loosen the nut turn the thing with a flat head counterclockwise until it gets hard to turn then turn it clockwise 1/4 turn
    bonos110's Avatar
    Sep 2007
    Battle Ground, WA
    is that to tighten it? "loosen the nut turn the thing with a flat head counterclockwise until it gets hard to turn"
    jlekson's Avatar
    Jan 2008
    Ham Lake, MN
    Just adjust that screw till it work good.
    -eagle-'s Avatar
    Apr 2004
    Southern Ohio
    Run the screw all the way out, then in 1/4.
    Nov 2007
    Warshingtun Stayt
    Thanks! Now before I do that, one more question........ When I kick my bike over, sometimes it does not "catch". It still has compression and once I kick it over about 3-5 times, it will turn over. It feels like the gear is stripped but it will eventually start. Could this be from the clutch not being adjusted?? THANK YOU ONCE AGAIN!
  7. #7
    bonos110's Avatar
    Sep 2007
    Battle Ground, WA
    well take the right side cover off and take a look to see if its stripped....
  8. #8
    Nov 2007
    Warshingtun Stayt
    Well you are just soooo smart Mr.B!! I am going to have to give you the "Facta Non Verba" medal! LOL! Probably a good idea to actually check huh?
  9. #9
    bonos110's Avatar
    Sep 2007
    Battle Ground, WA
    thats what were here for.
2008 klx 110 clutch adjustment
2011 klx 250s clutch adjustment
adjust klx250s clutch
clutch adjustment on klx 110
counter clockwise clutch klx
how do you adjust a clutch on a klx 110l
how to adjust clutch on klx 110
klx 110 adjusting clutch
klx clutch adjustment
klx110 clutch adjustment
klx250s clutch adjustment
