Jetting
Jetting
This is a discussion on Jetting within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a KLX110. It has a 143 Cyl and piston, stock head and 26mm carb. What jetting and needle setting should I be running? ...
Results 1 to 2 of 2
Thread: Jetting
    bstory1968's Avatar
    Apr 2007
    Forney, TX
    Jetting
    I have a KLX110. It has a 143 Cyl and piston, stock head and 26mm carb. What jetting and needle setting should I be running? It seems to be cutting out a little when you first get on the gas.
    bstory1968's Avatar
    Apr 2007
    Forney, TX
    Re: Jetting
    ttt
    Help?
klx110 26mm carb jetting
