KLX Motor Questions
This is a discussion on KLX Motor Questions within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a KLX motor being built right now with a TB143 V2 head kit and a stroker crank. How important is it to swap ...
KLX Motor Questions
I have a KLX motor being built right now with a TB143 V2 head kit and a stroker crank. How important is it to swap the countershaft with a heavy duty one? The only reason I ask is because my motor builder recomended I change it out, but I can't really afford the extra $200 right now. I have a huge Central American trip in a couple weeks, so money is tight untill then.
07-15-2008 04:16 PM
Re: KLX Motor Questions
you mean the output shaft? if thats what your asking i wouldnt build that nmotor without it
you dont wanna find out the hard way but i never had it with my 138 and was ok now with 178 i didnt take the chance.. if you can put in the hd output shaft
Originally Posted by
zbbt
oops, sorry. I ment the output shaft
just do it if possible if you dont and it breaks you might need to spend more if the pieces from it break other things
CannonFiveO
You can get the 08 kaw out put for $ 60.00
for $60 you cant go wrong
gotta split cases to put that in too though right?
jtblueberry
yes.
Sweeeet...now it looks like I will have over $1000 in this damn motor
Thanks for all the help!
yea...if not the bbr output i would get the kawi new one...i broke two stock ones with the holes in them and then replaced with the kawi new shaft without the hole...hasnt broke yet
don't forget to put the 4th gear in while you're in there
Went ahead and ordered a BBR output shaft. Motor should be back together before the weekend...I hope
CannonFiveO
Only a $1000??
That's cheap.
- You may not post replies
- You may not edit your posts
Forum Rules
